SeT Skrevet Juli 17, 2005 Skrevet Juli 17, 2005 Dls ca41 forsterker selges, Brukt i ca 3-4 uker! RMS output per channel at 13,8 volts Mode : AB Number of channels : 4 Nominal power output in 4 ohm (0,1% THD) : 4 x 50 W Typical power output in 4 ohm (0,1% THD) : 4 x 70 W Maximum power output in 2 ohm (0,2% THD) : 4 x 125 W Max power output in 4 ohm bridge mode : 2 x 200 W Frequency range : 10 Hz - 35 kHz S / N-ratio, A-weighted : > 100 dB Damping factor : > 100 Input impedance low level : > 10 kohm Input impedance, high level : 100 ohm Input sensitivity, variable : 0,25 - 5 V High level input with auto start : Yes Low level output : Yes Filter channel A & B : HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10) Filter channel C & D : HP: 15-500 Hz / 150 Hz - 5 kHz (x10) Grand bass adjustable frequency : 25 - 80 Hz Grand bass adjustable level : 0-18 dB Current draw, idle : 0,7 A Fuse value : 2 x 30 A Dimensions H x D x B : 67 x 354 x 250 mm (2,63 x 13,93 x 9,84 inch) Weight : 4,2 kg ( 9,3 lb) TS-W121SPL 12" sub selges Loads of decibels combined with solid power make the TS-W121SPL a force to be reckoned with. This high-quality subwoofer weighs in at +165 dB with a thumping 2000 W maximum power output. Borrowing some of the innovative ideas from its older brother, the TS-W5000SPL, this 30 cm subwoofer features a Glass fibre/Carbon fibre reinforced IMPP cone and a die-cast aluminium basket. With all of this and more, the TS-W121SPL has what it takes for your next SPL competition, or perhaps your next trip around the block! Key features TS-W121SPL Interlaced Glass Fibre/Carbon Fibre Reinforced IMPP cone Wide-roll, 3-layer fibre woven radial surround Double-stacked high power magnets Silver binding post terminal Aluminium die-cast basket with bottom hold structure Extended and vented pole yoke Dual 4 ohm voice coils (2 or 8 ohm) Optional accessories: - UD-G305 spoke grille - UD-W300S custom enclosure box Enclosure use Features TS-W121SPL Frequency response 18 - 2.000 Hz Sensitivity (1W/1m) 89 dB Qts 0.328 Recommended sealed enclosure (Litres) 42.5 Lowest resonance frequency (FS) 32 Hz Maximum Power 2.000 Watt Nominal input power 750 Watt Vas 34.53 l Woofer size (cm) 30 cm Dual 4-ohm voice coils: 2 or 8 ohm yes Power acoustiks gothic ov2-1600 2 kanals forsterker selges! STRØMSTERKE FORSTERKERE MED UTROLIG DYNAMIK OG PUNCH I LYDEN VARIABLE 18dB HP/LP S/N RATIO 97dB.THD:0,02% BLACKCHROME OG ALUMINIUM 2 X 370 WRMS 2OHM.740WRMS MONO (2 ohm) Kom med bud!
Mirakulix Skrevet Juli 18, 2005 Skrevet Juli 18, 2005 Nå har jeg ikke snnøring på hva slikt er verdt eller koster, har aldri brydd meg om noe spesielt om anlegg i bilen. Så lenge jeg kjenner bassen litt i magen, ser jeg meg fornøyd.. menne. 1000,- ?
Riefarn Skrevet Juli 18, 2005 Skrevet Juli 18, 2005 Bare basseren koster vel nå ca 1500kroner ny.....
jødahl Skrevet Juli 18, 2005 Skrevet Juli 18, 2005 Jeg kunne tenke meg forsterkeren. Men også jeg har lite peil på hvor mye dette koster nytt. Så hadde vært utrolig fint om du ga en prisantydning på det
mAZE Skrevet Juli 18, 2005 Skrevet Juli 18, 2005 DLS ca41 koster rundt 2500-2700,- på de billigste stedene i sverige. Fant ikke noe priser i norge i farten. http://www.prisjakt.nu/produkt.php?p=29613
jødahl Skrevet Juli 18, 2005 Skrevet Juli 18, 2005 ok, da er det veldig fint om du gir en prisantydning, for jeg er veldig interessert
SeT Skrevet Juli 18, 2005 Forfatter Skrevet Juli 18, 2005 Nypris: dls ca 41: 2495 Nypris TS-W121SPL 12" sub: 1495 Nypris Forsterker: 2895 tror jeg... var på tilbud-... veiledende pris på 3295 tror jeg!
jødahl Skrevet Juli 18, 2005 Skrevet Juli 18, 2005 Men hvor mye vil du/ forventer du å få for forsterkerne da?
SeT Skrevet August 3, 2005 Forfatter Skrevet August 3, 2005 Vært på ferie! Lar Power acoustiksen gå for 1400!
SeT Skrevet August 12, 2005 Forfatter Skrevet August 12, 2005 bump.... dls'en er fortsatt til salgs!!!
