BalleKnalle Skrevet September 12, 2005 Share Skrevet September 12, 2005 The basis for the was BMW M6, which underwent a performance upgrade. Optimising the entire engine management system and fitting an exhaust manifold system withl catalyst, sports rear silencer with tailpipe trims in "Sports Trim Design" help the TENSION achieve an incredible 406 kW / 552 HP.Even more imposing than the pure engine power is the maximum torque of 540 Nm at 6200 rpm, which pushes the driver back in the seat and catapults the TENSION to 100 km/h in just 4.5 seconds. The Vmax delimiter means that the acceleration thrust continues to 325 km/h before the speedo needle can relax. To achieve good deceleration values, development of a braking system was essential. On the front axle this takes the uncompromising form of an 8-pot fixed caliper with slotted and vented brake disks in (Ø 374 mm) and with 36 mm thickness. On the rear axle, a 4-pot fixed caliper is used. The wheels are also a new development: lightweight "Forged Wheel" with bi-colour finish embodies an apparent contradiction: reduction in weight with at the same time the largest possible diameters and widths. The TENSION is fitted with wheels size 10.0J x 20" all round. The offsets of -12 on the front and -2 on the rear allow tyres of size 285/30 ZR 20 and 325/25 ZR 20. To improve driving dynamics the TENSION has been equipped with an adjustable racing suspension. As well as lowering by 30 mm, the spring and damper rates have been clearly modified towards sporting performance. Furthermore antiroll bar kits and the specially developed strut brace in aluminium-carbon combination have been used. The TENSION body conversion is absolutely breathtaking, and is totally dedicated to optimising the aerodynamics. A further focal point of the development was the improvement of the air supply and extraction for the power plant and braking system. In comparison to the M6 a 50 mm wider body is the result of the complete conversion. At a glance: bonnet with power bulge, front skirt with large air intake, front wings with air outlet openings and 3 chromed ribs with integrated flashers, striking side skirts with large air shaft, rear skirt incl. unique underfloor wing construction with exchangeable diffuser, exchangeable rear wing. The interior is a combination of developments from the AC Schnitzer range and special one-off products. The AC Schnitzer TENSION was developed as a technology platform, which would cost around € 260,000.00. There are no plans for series production. Lenke til kommentar Del på andre sider More sharing options...
Lien Skrevet September 12, 2005 Share Skrevet September 12, 2005 .... fy fy fy fy fy fy faen! Råeste jeg har sett! Lenke til kommentar Del på andre sider More sharing options...
ovex Skrevet September 12, 2005 Share Skrevet September 12, 2005 FLOTT BIL! denne ga meg litt "Ferrari" følelse...og det er i mine auge eit kvalitetsstempel...(BMW er og eit kvalitetsstempel for all del) Lenke til kommentar Del på andre sider More sharing options...
Gunnar Skrevet September 12, 2005 Share Skrevet September 12, 2005 552 sugehester er jammen ikke ille... Lenke til kommentar Del på andre sider More sharing options...
Erik E30 Einum Skrevet September 12, 2005 Share Skrevet September 12, 2005 OJ-OJ-OJ!! Den der var spesiell, og rå! Moderator-edit: Endret til nyhet Lenke til kommentar Del på andre sider More sharing options...
elementz Skrevet September 12, 2005 Share Skrevet September 12, 2005 HEFTIG sier bare jeg.. Lenke til kommentar Del på andre sider More sharing options...
Dan Skrevet September 12, 2005 Share Skrevet September 12, 2005 Den var rålekker! Likte ytelsene på den der Lenke til kommentar Del på andre sider More sharing options...
Mangel Skrevet September 12, 2005 Share Skrevet September 12, 2005 Spør du meg så minner den meg om den nye mustangen i gt versjon og den er jo tøff, men det var søren meg denne her også! nice! Lenke til kommentar Del på andre sider More sharing options...
Schnellfahren Skrevet September 12, 2005 Share Skrevet September 12, 2005 OI ! Frekk fargekombinasjon! Den bilen kan skremme faen på flatmark! Lenke til kommentar Del på andre sider More sharing options...
Steffan C Skrevet September 12, 2005 Share Skrevet September 12, 2005 Mesterlig, vidundelig, ingen over, ingen ved siden . Lenke til kommentar Del på andre sider More sharing options...
Bart Skrevet September 12, 2005 Share Skrevet September 12, 2005 hadde ikke sagt nei til en slik en nei! damn den var rå! Lenke til kommentar Del på andre sider More sharing options...
Stjernstedt Skrevet September 13, 2005 Share Skrevet September 13, 2005 Flere STORE bilder http://www.e90post.com/forums/showthread.php?t=4385 Lenke til kommentar Del på andre sider More sharing options...
gsrl Skrevet September 16, 2005 Share Skrevet September 16, 2005 Seriøst!! Denne var ikke mye pen! Fronten ser jo helt jævli ut...Ser ut som bilen er underbitt:) Greie ytelser, men hallo.. Jaja, smaken er som baken;) Lenke til kommentar Del på andre sider More sharing options...
mAZE Skrevet September 16, 2005 Share Skrevet September 16, 2005 Synes det ble litt MB preg over luftinntaket på siden, men men.. RÅ bil.. Lenke til kommentar Del på andre sider More sharing options...
DaggEn Skrevet September 16, 2005 Share Skrevet September 16, 2005 Syns denne bilen var skamfet men er ikkje helt sikker på fargen.. Kansje, kansje ikkje.. Hadde sikkert vagt oppsikt Lenke til kommentar Del på andre sider More sharing options...
