Peoplez Skrevet Januar 15, 2006 Skrevet Januar 15, 2006 Sjekklister for Inspeksjon I og Inspeksjon II Noen som har ei oversikt?
Lien Skrevet Januar 15, 2006 Skrevet Januar 15, 2006 BMW Inspection I Undercarriage 1. Change engine oil and filter while engine is at normal operation temperature. 2. Check transmission for leaks. 3. Check rear axle for leaks. 4. Visually check fuel tank, lines, and connections for leaks. 5. Check condition, position, and mounting of exhaust system. Examine for leaks. 6. Check power steering system for leaks. 7. Check overall thickness of front and rear disc brake pads. 8. Examine brake disc surfaces. 9. Clean brake pad contact points in calipers. 10. Grease wheel center hubs. 11. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc. 12. Check front control arm bushing for wear. 13. Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning. 14. Check for free movement of the parking brake cables. Adjust parking brake if necessary. 15. Check all tire pressures (including spare). Correct if necessary. 16. Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required. Engine Compartment 1. Read out diagnostic system 2. Check engine cooling system/heater hose connections for leaks. 3. Check coolant level and antifreeze protection level; add coolant if necessary. 4. Check level of brake and clutch fluid in reservoir; add fluid if required. 5. Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. 6. Check air conditioner for operation. 7. Reset Service Indicator. Body/Electrical Equipment 1. Check battery electrolyte level and add distilled water if required. 2. Perform batter load test. 3. Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights. 4. Check instrument panel and dashboard illumination. 5. Check all warning/indicator lights, check control. 6. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch. 7. Check wiper and washer system(s); wiper blades, washer jet positions. 8. Check condition and function of safety belts. 9. Oil hood, trunk/tailgate, and door hinges. 10. Grease hood, trunk/tailgate and door latches. Check operation of all latches. 11. Check central locking/double lock. 12. Replace microfilter or Acc. Cabin Filter. 13. Check heater/air conditioner blower, rear window defogger. 14. Check rear view mirrors 15. Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories. Final Inspection 1. Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission Inspection II Undercarriage 1. Change engine oil and filter while engine is at normal operation temperature. 2. Check transmission for leaks. 3. Check rear axle for leaks. 4. Visually check fuel tank, lines, and connections for leaks. 5. Check condition, position, and mounting of exhaust system. Examine for leaks. 6. Check power steering system for leaks. 7. Check overall thickness of front and rear disc brake pads. 8. Examine brake disc surfaces. 9. Clean brake pad contact points in calipers. 10. Grease wheel center hubs. 11. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc. 12. Check front control arm bushing for wear. 13. Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning. 14. Check for free movement of the parking brake cables. Adjust parking brake if necessary. 15. Check all tire pressures (including spare). Correct if necessary. 16. Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required. 17. Check thickness of parking brake linings. 18. Half-shafts; check for leaks at flexible boots. 19. Inspect entire body according to terms of rust prevention limited warranty. Engine Compartment 1. Read out diagnostic system 2. Check engine cooling system/heater hose connections for leaks. 3. Check coolant level and antifreeze protection level; add coolant if necessary. 4. Check level of brake and clutch fluid in reservoir; add fluid if required. 5. Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. 6. Check air conditioner for operation. 7. Reset Service Indicator. 8. Replace spark plugs. 9. Replace intake air cleaner element. Body/Electrical Equipment 1. Check battery electrolyte level and add distilled water if required. 2. Perform batter load test. 3. Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights. 4. Check instrument panel and dashboard illumination. 5. Check all warning/indicator lights, check control. 6. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch. 7. Check wiper and washer system(s); wiper blades, washer jet positions. 8. Check condition and function of safety belts. 9. Oil hood, trunk/tailgate, and door hinges. 10. Grease hood, trunk/tailgate and door latches. Check operation of all latches. 11. Check central locking/double lock. 12. Replace microfilter or Acc Cabin Filter. 13. Check heater/air conditioner blower, rear window defogger. 14. Check rear view mirrors 15. Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories. Final Inspection 1. Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission Oil Change Service 1. Drain and refill your vehicle's crankcase with BMW approved oil. Install a new genuine BMW oil filter 2. Check all other Fluid levels, and top off as necessary. 3. Check and adjust tire pressure. 4. Fill windshield washer fluid. 5. Reset oil light
Kjetil Sømme Skrevet Januar 15, 2006 Skrevet Januar 15, 2006 Oilservice, Inspection I og II sine sjekkpunkter varierer med hvilken "Production Code" bilen har. Min er en BN51, og jeg må taste inn siste 7 siffer av chassisnummer i BMW TIS for å få en komplett liste over ting som skal gjøres. Denne listen blir også oppdatert over tid fra BMW AG, hvis de oppdager at noe bør sjekkes/smøres/byttes oftere eller mer sjelden enn tidligere. Derfor varierer prisene på servicene også ganske mye, fordi noen biler har mange flere sjekkpunkter enn andre. Har man TIS kan man skrive ut en flott sjekkliste som egentlig skal gis til kunden og underskrives av mekaniker og kundemottaker etter at service er fullført. Jeg skal sjekke om det er mulig å sende over en service-liste fra TIS elektronisk.
Kjetil Sømme Skrevet Januar 15, 2006 Skrevet Januar 15, 2006 Sjekket i TIS nå. Jeg får bare skrevet ut, men jeg skal installere en Adobe-pdf skriver slik at jeg kan lage en pdf for å vise prinsippet. Forøvrig er det 4 ulike skjemaer til 330Ci coupe. 2 ulike skjemaer til BN51 og BN61 Og 2 andre skjemaer til BD51 og BD61 som gjelder fra 09/2002 Så dette er ikke som en toyota eller VAG-greie. Her er det tysk nøyaktighet som gjelder!
Kjetil Sømme Skrevet Januar 15, 2006 Skrevet Januar 15, 2006 Sjekklister for Inspeksjon I og Inspeksjon IINoen som har ei oversikt? Hvis du har 7 siste tegn av chassisnummeret ditt, så kan jeg få tatt ut en liste til din bil.
aloebiz.net Skrevet Januar 20, 2006 Skrevet Januar 20, 2006 hei! kan ta ut en liste til meg for min e39? siste 7 tegn i chassinr er: BT46063
Peoplez Skrevet Januar 20, 2006 Forfatter Skrevet Januar 20, 2006 Sjekklister for Inspeksjon I og Inspeksjon IINoen som har ei oversikt? Hvis du har 7 siste tegn av chassisnummeret ditt, så kan jeg få tatt ut en liste til din bil. har berre reg nr. bp69918. sjekkker du opp eller?
Kjetil Sømme Skrevet Januar 20, 2006 Skrevet Januar 20, 2006 Venter på at 2000 gb skal skrives på raidsettet mitt før servern kommer opp igjen. Den har stått i 36 timer nå... Men jeg skal lage lister til dere. Jeg skal finne chassisnummer utifra regnummer jeg
Stjernstedt Skrevet Februar 18, 2006 Skrevet Februar 18, 2006 På min e36 så lyser Oil Service lampa nå, hva skjer på olje service? Kun skifting av olje og filter? Hvor mye må jeg punge ut? Tenker da på et merkeverksted (Stenshagen)
Kjetil 323i E36 Skrevet Februar 19, 2006 Skrevet Februar 19, 2006 På min e36 så lyser Oil Service lampa nå, hva skjer på olje service? Kun skifting av olje og filter? Hvor mye må jeg punge ut? Tenker da på et merkeverksted (Stenshagen) Dette ville jeg tatt en ringerunde på. Prisene til de forskjellige verkstedene varierer mye etter hva jeg har erfart, så har du flere "forhandlere" i nærheten av deg, ring til alle.
Kjetil Sømme Skrevet Februar 19, 2006 Skrevet Februar 19, 2006 Har ikke servern blitt ferdig ennå? Ooops. Glemte hele greia. Skal sjekke etter frokost...
Arimanni Skrevet Februar 19, 2006 Skrevet Februar 19, 2006 Sjekklister for Inspeksjon I og Inspeksjon IINoen som har ei oversikt? Hvis du har 7 siste tegn av chassisnummeret ditt, så kan jeg få tatt ut en liste til din bil. Program du bruker?!
