Gjest Skrevet April 29, 2006 Skrevet April 29, 2006 Jeg har fått løst det dekselet som ligger i overkant av tanken, samt det lokket som er under der igjen.. har tatt ut den pumpegreia, men selve bensinpumpa sitter litt innunder tanken.. nå var det riktignok mørkt ute da vi prøvde å få den ut, men: Finnes det noe rask måte å få den ut på? tips? (E34)
2RE_Racing Skrevet April 29, 2006 Skrevet April 29, 2006 In-tank fuel pump or transfer pump 14 On some models, access to the fuel pump is gained by removing the rear seat cushion. On other models, access is gained by removing the carpet from the luggage compartment. 15 Remove the screws from the fuel pump access cover (see illustration). 16 Remove the cover. 17 Locate the fuel pump and sender unit electrical connectors (see illustrations) and unplug them. Also, disconnect the fuel inlet and return lines. 18 On some models, the assembly must be rotated anti-clockwise to disengage the locking lugs from the fuel tank (see illustration). On other models, the assembly is secured to the tank with nuts (see illustration). Carefully lift the assembly from the fuel tank (see illustrations). It may be necessary to twist the assembly slightly, to get the float to clear the opening. 19 On early models, remove the transfer pump mounting screws and clamps, and separate the transfer pump from the assembly. 20 Refitting is the reverse of removal. If the gasket between the fuel pump and fuel tank is dried, cracked or damaged, renew it. I følge haynez
Gjest Skrevet April 30, 2006 Skrevet April 30, 2006 Jepp.. jeg fant ut av det.. var ikke så veldig komplisert.. men anbefaler alle som skal gjøre dette om å ikke ha full tank:p
