V-Drive Blue Anodized Inverted Heat Sink Design
Dual VU Metering System with
Acrylic Lens
Mesh Grille Ventilation Design
Chrome Heat Sink Cover
PWM Mosfet Power Supply
Fully Bridgeable Design
Blue High Quality PCB Design
UltraùDrive High Speed Mosfet Output Devices
Class AB Operation
On Board Tru-Spec Capacitors
Premium Hand Wound Torroid
Separate Bass and Treble Controls
Bass/Treble On/Off Switch
HP (High Pass) from 10 Hz to 30 KHz Adjustable Crossover Network with Subsonic Filter
HP/LP/Flat Select Switch
LP (Low Pass) from 40 Hz to 4 KHz Adjustable Crossover Network
Gold Plated RCA Line Input
Gold Plated RCA Line Output for Amplifier Daisy Chaining
Internal ProtectionùThermal, Short Circuit, Overload Circuitry
Red Protection LED
Green ""On""LED
Two Channel WATTAGE DIMENSIONS
V-Drive
V-2800 High Power
2 x 350 Watts 4 Ohms
2 x 500W @ 2 Ohms
1 x 1000 @ 4 Ohms Music Power 1600 Watts WxHxL 10.33" x 2.06" x 20.6"
[262 mm x 52.32 mm x 522 mm]
Bilder kan sendes på mail. Selges til høyest bud!!!
Har også denne, Crunch V-2300.
Plastikken rund GND kontakten er smeltet, men forsterkeren virker helt perfekt.
- High Power
- 2 x 150 Watts 4 Ohms
- 2 x 225W @ 2 Ohms
- 1 x 450 @ 4 Ohms Music Power 600 Watts
- WxHxL 10.33" x 2.06" x 11.3"
- V-Drive Blue Anodized Inverted Heat Sink Design
- Dual VU Metering System with Acrylic Lens
- Mesh Grille Ventilation Design
- Chrome Heat Sink Cover
- PWM Mosfet Power Supply
- Fully Bridgeable Design
- Blue High Quality PCB Design
- Ultra—Drive High Speed Mosfet Output Devices
- Class AB Operation
- On Board Tru-Spec Capacitors
- Premium Hand Wound Torroid
- Separate Bass and Treble Controls
- Bass/Treble On/Off Switch
- HP (High Pass) from 10 Hz to 30 KHz Adjustable Crossover Network with Subsonic Filter
- HP/LP/Flat Select Switch
- LP (Low Pass) from 40 Hz to 4 KHz Adjustable Crossover Network
- Gold Plated RCA Line Input
- Gold Plated RCA Line Output for Amplifier Daisy Chaining
- Internal Protection—Thermal, Short Circuit, Overload Circuitry
- Red Protection LED
- Green "On"LED
