Pioneer GM-7100M forsterker. Klarer den å dra dette?
Jeg lurer på om en Pioneer GM-7100M forsterker klarer å dra to stk 12" Sony Xplod subwoofere på 1200w maks effekt og 350w RMS? Dette er spesifikasjonene på forsterkeren:
* Mono channel capability 1 x 800 (2 Ω) W or 1 x 500 W (4 Ω) (Max. Power)
* Continuous output power: 1 x 360 W (2 Ω) or 1 x 250 W (4 Ω)
* 1 x 380 W (4 Ω) DIN Power (DIN 45324, +B = 14.4 V)
* Load impedance capability (2 — 8 Ω)
* Variable LPF( -12 dB/Oct): 40 - 240 Hz
* High Voltage Input capability (200 mV — 6.5 V)
* PWM regulated MOSFET power supply Yes
* Input level/gain control
* Load impedance capability 2 - 8 Ohm
* Bass Boost 50 Hz - 0/6/9/12 dB (Remote)
* RCA input terminals
* Speaker Terminals: Screw-type
* Power / ground terminals: Large screw-type
* LPF 40 - 240Hz (Variable)
* High voltage input capability 200 mV - 6.5 V
* High performance balanced isolator circuit
* Frequency response 10 Hz - 240 Hz
* Distortion 0,030 %
* S/N ratio > 100 dB
* High Voltage Input Capability 200 mV - 6.5 V
* Max. current consumption (A/4ohms) 33 A
* Chassis size (W x H x D) 300 x 60 x 327 mm
* Unit weight 4.7 kg
