sh0rty^ Skrevet Mai 1, 2007 Skrevet Mai 1, 2007 Selger en macrom forsterker som fremstår som ny, brukt en sommer sesong. Type Macrom M1A.275 500 watts IHF Power - 2 x 105 watts rms into 2 ohms load 14 volts - 2 x 75 watts rms into 4 ohms load 14 volts - 1 x 210 watts rms into 4 ohms load 14 volts - 12dB low pass x-over, variable from 30 to 600Hz - 12dB/oct high pass line out, variable from 30 to 600Hz - Chrome heatshield - EBC external bass control - Pre-amplified output with crossover options - Muting circuitry for soft turn-on and turn-off - PWM Mos-Fet power supply - 2 ohms compatible in stereo, 4 ohms compatible in bridge mode - High level input - Frequency response : 10 to 50.000Hz (+/-0,5dB) - Sensitivity : 0,2 to 8 volts compatible - Total Harmonic Distortion : THD < 0,01% - Signal to noise ratio : > 100dB - Dimensions : 265 x 50 x 220 mm Selger også en basskasse med plexiglass og lys som inneholder 2 x Boss 12" elementer. Spiller veldig bra. 93203098 Bud ønskes. Kan hentes i telemark, eventuelt bli enige om å møtes. ved seriøs interesse kan bilder ordnes.
