Legger ut for og skjekke interessen.
Magnat The Rock 1000 2-channel 1000W Amplifier
2 ohm stable Variable low-and high pass 40 - 300 Hz (12 dB per octave) Variable bass boost 0...12 dB at 45 Hz Channel mode selector switch (4/3/2/1 - different models) Low level RCA outputs provide summing signal of channel 1 to 4 for use with a subwoofer amplifier. Low level pass through RCA jacks Bridge- / Tri-mode capability Protection circuit that safeguards against short circuits, DC-offset and overheating Green operation and red protection indication LED
Principle 2-channel Car Hifi amplifier
Max power output into 4 ohms Sinus Burst 2:8, 1kHz, 14,4V
for channels 1-2
Stereo 2x320 Watt
bridge boat 1x1000 Watt
RMS power output into 4 ohms DIN 45324, 14,4 V
for channels 1-2
Stereo 2x165 Watt
bridge boat 1x540 Watt
Max.power output into 2 ohms Sinus Burst 2:8, 1kHz, 14,4V
for channels 1-2
Stereo 2x500 Watt
RMS power output into 2 ohms DIN 45324, 14,4 V
for channels 1-2
Stereo 2x260 Watt
Impedance Channel 1 2-8 Ohm
Impedance Channel 2 2-8 Ohm
Impedance Channel 3 2-8 Ohm
Impedance Channel 4 2-8 Ohm
Frequency response 5 Hz - 50 kHz (-3dB)
THD << 0,05%
Übersprechdämpfung > dB
Signal-to-noise ratio >> 100 dB dB
Input sensitivity LOW LEVEL INPUT 0,25V - 4V
Input impedance LOW LEVEL INPUT 20 kOhm Ohm
Variable low pass channel 1 from 40 Hz
Variable low pass channel 1 to 300 Hz
Flankensteilheit Tiefpassfilter 12 dB / Oktave
Variable high pass channel 1 from 40 Hz
Variable high pass channel 1 to 300 Hz
Variable Bass Boost to 12
supply 12V (10-15V)
Også en Jbl kasse som jeg er usikker på informasjon om! Kostet 2000kr ny har jeg fått hørt.
Ta kontakt om dere er interesert
