Mocal/tilton oljepumpe selges
Flow Rate @ 12 Volts (gpm) 1-2
Hose Material Rubber
Notes 3/8 inch NPT inlet and outlet size.
Power Supply 12 V DC
Temperature Range (degrees F) 0 to 265
Working Pressure (psi) 60
Oil Cooler Pump, Transmission/Differential, Each
These Tilton transmission/differential oil cooler pumps are positive displacement-type pumps that produce output directly proportional to motor speed. They're lightweight, self-priming pumps that may be mounted in any position up to several feet away from the tank.
  • 3 weeks later...
