VS: Kraftig 2-kanaler - Soundstream PCA2.760
På grunn av feilkjøp må jeg sannsynligvis selge denne kraftige 2-kanaleren.
(er den øverste av dem)
Har kun åpnet boksen og tatt bilde av den, så helt ubrukt.
Litt specs:
2 Channel Amplifier
Fully-Regulated MOSFET Power Supply
PWM Circuitry
Tri-Guard Amplifier Protection
IDIT (Intelligent Distress Indicator) Gives a Visual Indication of the Amplifiers Protection Status
Line Outputs
Bi-Linear Selectable Crossovers for Inputs and Outputs (Hi/Full/Low)
Continuously Variable High and Low-Pass Crossovers
Variable Subwoofer Equalizer
Phase Inversion Switch (0 - 180º)
OEM Floating Ground Input
Platinum 4-Gauge Power Connectors
RMS @ 4 Ohms 220x2
RMS @ 2 Ohms 380x2
RMS @ 4 Ohm Mono 760x1
1520 Watts Max
T.H.D.: 0.02%
Frequency Response: 10Hz-30kHz
Signal to Noise Ratio: >97dB
Damping Factor: >200
Input Sensitivity: 0.2-6.0V
Crossover Slopes: 12dB
Subwoofer EQ: 0-18dB
Subwoofer EQ Freq.: 40Hz-120Hz
DIMENSIONS (INCHES): 9.5 x 2.5 x 20.0
Ønsker bud, men selges IKKE for under 2000kr
Kan leveres mellom Kristiansand og Stavanger
  • 2 months later...
