Solgt!!
Strøken konkuranse subwoofer selges for 1100.- Subwooferen er kun brukt i en uke og selges på grunn av en annen løsning.
Nypris: 1995,-
Interlaced Glass/Carbon Fibre Reinforced IMPP double cone
Wide-roll, 3-layer Fibre woven radial surround
Double cone reinforcement nodes
Powerful double-stacked magnets
High power handling ceramic-coated voice coils
Bottom hold design aluminium die-cast chassis
Aluminium die-cast heat sink
Spring compression binding terminals
Nominal input power: 1000 W
Frequency response 18 - 700 Hz
Sensitivity (1W/1m) 89 dB
Recommended sealed enclosure (Litres) 24.1 - 49.5
Lowest resonance frequency (Hz) 26.2
Maximum input power 3.000 Watt
Nominal input power 1.000 Watt
Woofer size (cm) 30 cm
Dual 4Ω voice coils: 2 or 8Ω Yes
Sendes som Norgespakke/evt hentes.
  • 2 months later...
