Rustfri Sportseksos fra umnitza.com passer 325, 328 og US M3
Er så og si samme eksosen som UUC sin og det eneste som er forskjell er UUC innskripten på endestussene. (utsagn fra bimmerforums). Denne eksosen koster 4700 inkl moms og frakt fra USA.
Denne har vært montert på bil i ca 1 uke og skal selges da jeg har fått tak i et Eisenmann effektanlegg.
Eksosen er særdeles lett og montere. Plug and play og har en veldig god passform. Bilstein eksosoppheng 2 stk (nye i åpnet eske) kan fåes med viss ønskelig (veil pris ca 300).
lyd kan høres
Lyden er særdeles lik på min 328 som den er på denne M3'en? på filmen.
Beskrivelse fra Umnitza.com
Item Description
Title:
Exhaust - Exclusively from Umnitza
By using two completely separate silencers, this exhaust design maintains separate exhaust gas paths from the catalytic converters right through to the outside atmosphere. The result? Awesome sound, unique appearance, and the performance you expect!
CLASS LEADING FEATURES:
100% 304 stainless steel construction (including interior parts), all welded.
TRUE dual 60mm (2.38") diameter inlet piping, about 1/3" larger than practically all other performance exhausts.
Full cat-back system.
Completely TIG-welded.
Only 23lbs (compare to stock at 49lbs).
Fully polished.
Deep mellow tone without being overly loud.
Why twin silencers? Looking closely at your E36's exhaust path, gases leave the combustion chamber via sequential manifolds, and briefly intermingle in a single collector before splitting back into two paths and passing through the catalyzing and resonating portions of the exhaust. Conventional wisdom holds that inline-6 engines respond well to a shared muffler before exiting the exhaust path. But with the complicated system of components already installed on your, there is little or no scavenging effect left to be had at the rear of the car.
What's it like on the car? This starts up and idles with little hint that you have a performance exhaust. But once you tip into the throttle, the deep, pleasant tone and slight burble let discerning listeners know that this is not your ordinary E36. All Exhausts Sold for 'Off-Road' Use Only - No Warranty or Certification
is Expressed or ImpliedAs revs increase, the tone only gets sweeter, emitting a wail that only an Italian car can match. Cruising on the highway is blessedly relaxed, with no droning in the middle revs, and a mellow sound on long trips.All Exhausts Sold for 'Off-Road' Use Only - No Warranty or Certification
weight savings: it is 25lbs lighter than your original equipment exhaust.
extra ground clearance: this exhaust sits higher so it doesn't scrape
extra tire clearance: it does not intrude into the wheel opening.
versatile mounting height capability for cars that have aftermarket body kit.
Link til Umnitza.com
Kom med bud...
kor mye ska du ha for eksosannlegget da?? hvor befinner d seg??
og sko vist om d passer m3 for d er d jeg har
Application (Please consult your owner's manual for your application fitment type):
All Available for 6-cylinder 1992-1999 E36 (M3, 325, and 328. Not 323).
Vel, Produsenten sier at den passer, så da bør det stemme...
Hva hadde du tenkt deg for den nå da?
Eksosanlegget befinner seg i Bergen. bare å komme med bud. ingen som har sagt noe ennå. Eksosanlegget må vekk uansett. om den går for 1000 eller 4000 blir opp til budgiverne... bare for å sette det på spissen.
Eksosanlegget er å finne i Bergen. bor sentralt...
Det passer vell US M3, som har 3 Liters M50. Tror ikke at det passer EURO M3.
Hvor langt bak går anlegget?
Du har sikkert et godt poeng der.... lurte på det, men de pleier nemlig å skrive non-euro e.l. da.... skal sende en mail til umnitza og forhøre meg... ikke sikkert jeg får svar... av og til får jeg, av og til ikke...
