Soundstream forsterker/sub (nye priser)
To-kanaleren og monoblokken har alle så å si samme design. Bare størrelsen som varierer. Kan sende bilder av de jeg har hvis du vil se nøyaktig hvordan den du er interessert i ser ut.
To av forsterkerne er brukt noen få timer mens siste forsterker og sub har aldri blitt brukt. Ser så godt som nytt ut, og leveres i orginal embalasje
To kanalers:
Soundstream PCA 2.520
Technical Specification
RMS Power Range : 160-260 Watts
Number Of Channels: 2
Maximum Power: 520 Watts
Low Frequency response: 10 Hz
High Frequency Response: 30000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
No. OF CHANNELS: 2
OUTPUT (watts):RMS @ 4 Ohms 160x2
RMS @ 2 Ohms 260x2
RMS @ 4 Ohm Mono 520x1
T.H.D.: 0.02%
FREQ. RESPONSE (Hz): 10 - 30k
SIGNAL TO NOISE RATIO: >97dB
DAMPING FACTOR: >200
INPUT SENSITVITY: 0.5 - 4.0V
CROSOVER SLOPES: 12dB
CROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600
Low-Pass(Hz) 50 - 150
SUBWOFFER EQ: 0 - 18dB 0
SUBWOOFER EQ FREQ. (Hz) : 40 - 120
DIMENSIONS (INCHES): 9.5x2.5x15.0
Fully regulated MOSFET power supplies
PWM circuitry
Tri-guard amplifier protection
IDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
Platinum RCA inputs and outputs
Line Outputs
Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
Continuously variable high and low-pass crossovers
Variable subwoofer equalizer
Phase inversion switch (0 - 180)
OEM floating ground input
Platinum 4-gauge power connectors
Tri-mode operation
Optional Remote Bass Control (EGA-RM)
Soundstream PCA 2.760
RMS Power Range : 220-380 Watts
Maximum Power: 760 Watts
Features
No. OF CHANNELS: 2
OUTPUT (watts):RMS @ 4 Ohms 220x2
RMS @ 2 Ohms 380x2
RMS @ 4 Ohm Mono 760x1
T.H.D.: 0.02%
DIMENSIONS (INCHES): 9.5x2.5x20.0
PWM circuitry
Line Outputs
Tri-mode operation
Monoblokk:
Soundstream PCA 1500D
RMS Power Range : 800-1500 Watts
Number Of Channels: 1
Maximum Power: 3000 Watts
Low Frequency response: 5 Hz
High Frequency Response: 250 Hz
Features
Monoblock Picasso Series Amplifier
Peak Power Output: 3000 watts approx.
RMS Power Ratings:
800 Watts x 1 Channel @ 4 Ohms
1100 Watts x 1 Channel @ 2 Ohms
1500 Watts x 1 Channel @ 1 Ohm
Bridged RMS Power: Not Bridgeable
Min. Impedance Unbridged: 1 ohm
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: 0.5%
Speaker Level Inputs: No
Amp Preamp Outputs: 1 Pair
Built-in Crossover: LP (50 - 150 Hz), Subsonic (15 - 40 Hz)
Bass Boost: 0 - 18 dB
Signal-to-Noise Ratio: 80 dB
Fan Cooled: No
Fuse Rating: N/A
TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
High Quality FR-4 Circuit Board
Class D Circuitry
Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
Variable Subwoofer Equalizer: 0 - 18 dB
Phase Control: 0� / 180�
Frequency Response: 5 - 250 Hz
Adjustable Input Sensitivity: 0.5 - 4V
Damping Factor: >200
Fully Regulated MOSFET Power Supply
PWM Circuitry
Platinum Power and Ground Connectors
Accepts up to 16VDC Power Input
Wire Bass Remote Included
Dimensions: 15" L x 9-1/2" W x 2-1/2" H
http://www.xelent.no/elementvisning.php?PID=351
Sub:
T5-12
* Sensitivity: 84.9 dB
* RMS Power Range : 900 Watts
* Impedance: Dual 2 Ohm
* Low Frequency response: 30 Hz
* High Frequency Response: 300 Hz
* Diameter: 12 Inch
Features
* Cast Aluminum Basket
* Hand Laid Pulp Paper Cone
* One Piece Gasket/Tall Rubber Surround
* Large PP Injected Dust Cap
* Dual Stacked Magnet Assembly (Triple Stack on T5-15)
* Dual 2 Ohm 3� Aluminum Voice Coil
* Vented Back Plate
* Integrated Tinsel Leads
* Nickel Plated Push Terminals
* Durable ABS Plastic Motor Cover
Ca 2000kr for den minste, 2500kr for den mellomste, 3500kr for monoblokken og 2000kr for suben.
Setter ned prisene til 1500kr for PCA2.520 og 2000kr for PCA2.760.
Monoblokken går for 2500kr!!!
  • 3 weeks later...
  • 1 month later...
