mort Skrevet Januar 11, 2009 Skrevet Januar 11, 2009 Har ein 15" GZ sub som eg må bli kvitt. An e limte i konen siden den har løsna.. Ser ikkje så fantastisk ut, men an virke akkurat sånn så an ska. Håpe å få bytta an i effektforsterkar eller surround forsterkar An e 2x3.6ohm. diameter: 38 cm / 15" power handling: 5.000 WRMS voice coil: 100 mm / 4" flat wire excursion: X max. 75 mm / 3" resonance frequency: FS 30 Hz Qts 0.27 Vas 49 liters SPL 91.3dB additional: VOXR surround double spider Gir og cash i mellomlegg viss nåken har ein skikkelige surroundreciever di vil bytta i edit: Har og 2 stk B&W høytalerar eg sko blitt kvitt Floor standing, two way passive loudspeaker, designed for domestic hi-fi systems. Bi-wiring / bi-amplification facility. Drive units: One 200mm (8") bass/mid with rigid diecast chassis, reinforced polypropylene diaphragm and 31mm (�") high temperature voice coil on Kapton former. One 26mm (1") high frequency with metal dome, high temperature voice coil and magnetic fluid cooling. One passive bass radiator with long throw capability. Frequency range: -6dB at 44Hz and 30kHz Frequency response: 58kHz - 20kHz (� 2dB) Reference Axis: Horizontal 605mm from bottom of cabinet. Dispersion: within �2dB of response on reference axis 20Hz - 15kHz Horizontal over 40� arc, Vertical over 10� arc Sensitivity: 90dB (2.83V, 1 metre) Impedance: Nominal 8 Ohms Crossover frequency: 3kHz Internal volume: 30. litres Power handling: suitable for amplifiers 25 - 100 Watts Dimensions: 742 (H) x 236 (W) x 302 (D) mm Weight:: 14.2kg
