E32 750 M70 - E32 Alpina B12
E32 alpina b12 1991
engine V12
displacement 4988 cc / 304.4 cu in
bore 84 mm / 3.31 in
stroke 75 mm / 2.95 in
compression 9.5:1
power 261.0 kw / 350.0 bhp @ 5300 rpm
hp per litre 70.17 bhp per litre
bhp/weight
torque 470 nm / 346.7 ft lbs @ 4000 rpm
front wheels F 43.2 x 21.6 cm / 17.0 x 8.5 in
rear wheels R 43.2 x 25.4 cm / 17.0 x 10.0 in
front tire size MMX2 235/45ZR17
rear tire size MMX2 265/40ZR17
weight 1860 kg / 4101 lbs
wheelbase 2833 mm / 111.5 in
length 4910 mm / 193.3 in
width 1845 mm / 72.6 in
height 1391 mm / 54.8 in
transmission 4-Speed Auto
gear ratios 2.48:1, 1.48:1, 1.00:1, 0.73:1
final drive 3.45:1
top speed 275 kph / 170.9 mph
0 - 60 mph 6.8 seconds
dette er 750 1988
Displacement: 5 L (4988 cc, 304 cu in)
12 cylinder V-arrangement 60 degree
24 valves
Compression: 8.8:1
Stroke/Bore: 75 mm (3 in)/84 mm (3.3 in)
Firing Order: 1-7-5-11-3-9-6-12-2-8-4-10
Max power: 220 kW (295 hp) @ 5300 rpm
Max torque: 450 N·m (332 lb·ft) @ 4000 rpm
Max rpm: 6000–6400 rpm *Gearing
redline 6000.
Det er forskjellige stempler som gjør at kompresjonen blir høyere. Større innsug ventiler, høyere ventil løft. Også endra ventil timinga.. skulle tru det var det meste..
Så er nok ikke bare elektronikken
Rett meg hvis jeg tar feil. ! =)
