Haltech E6K (Datasprut+tenning) bolton til M50 +++
Selger nå mitt datasprut da jeg skal prøve noe annet.
Haltech E6K (Dos-programvare) ECU
Komplett Haltech E6K ledningsnett
3bars mapsensor
3x dobble Haltech coiler
Silikon High Output pluggledninger
Bosch tenningsforsterker med 3x tennsteg, med kjøleribbe
Manual med all info som trengs
Jeg har gitt over 15 000,- for dette for et par år siden, dette går som en pakke for høystbydende over 7000,-.
Dette er tenningsystem som holder over 400hk, og jeg bremset selv 362bakhjulshester med det.
PM/Svar her/SMS
93259459 - Bjørn
Info om sprutet:
The Haltech E6K and E6X are powerful "real time" programmable fuel injection and ignition computers designed to control most ignition type engines. Whether 1-6, 8, 10, or 12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or supercharged, the Haltech E6K and E6X can control it.
More than a programmable fuel injection computer - it provides logging of engine data and allows access in real time to maximize performance and troubleshoot problems in a vehicle while running. Typical Applications include:
Conversion from carburetion to fuel injection
Control of fuel injection on modified engines
Race and rally applications of all descriptions
Design and development purposes
Educational use by universities and colleges
Original equipment in cars and motorcycles
E6K Features
4 additional pulse width modulated outputs over the E6M
8 injector drivers as standard equipment
An internal barometric pressure sensor
Enhanced BAC valve control
Enhanced wastegate control
E6K User Configurable Outputs:
Closed loop idle speed
Electronic boost control
Thermofan
NOS enable
BAC valve
Shiftlighting
Stall-saver
Anti-lag
Turbo Timer
VTECH
Rev limiter
Air con
Closed loop O2 sensor
Deceleration fuel cut
Intercooler fan
Aux. fuel pump
staging signal
torque convertor
dual intake valve
Passer dette 325 vanos?
Dette passer rett på alle 320 og 325 (M50), men må såklart mappes for din motor!
Hvordan turbo har du brukt, og passer dette rett på en 91 mod, uten noen form for modifikasjon.
Jeg brukte en t3 kina turbo.
Min egen bil er 91mod, så burde åasse rett på! Med dette ledningsnettet kan man bare fjerne det orginale ledningsnettet, dette er komplett!
Sprutet kan settes på en hvem som helst motor, f.eks M20 osv.
Ledningsnett er tilpasset å sitte på en M50, men med litt skjøting av kabler osv kan dettesitte i hvem som helst motor. Med tenningen osv er det selfølgelig enklest med en 6syl.
