Effektbrett for de som spiller gitar.
selger et effektbrett av typen Boss ME-50.
specs er som følger:
AD Conversion 24-bit + AF method*
DA Conversion 24-bit
Sampling Frequency 44.1 kHz
Patches 30 (user)
Effects Tone Modify, Compressor, Overdrive/Distortion, Chorus, Phaser, Flanger, Harmonist, Tremolo, Pan, Vibrato, UNI-V, Rotary, Delay, Reverb, Noise Suppressor [Effects for Expression Pedal]: Foot Volume, Wah, Resonance, Voice, RIng Modulator, Bend (+1 OCTAVE, -1 OCTAVE)
Nominal Input Level INPUT: -10 dBu, AUX IN: -10 dBu
Input Impedance INPUT: 1 M ohms, AUX IN: 100 k ohms
Nominal Output Level -10 dBu
Output Impedance 2 k ohms
Display 7 segments, 1 character LED
Jacks INPUT jack, GUITAR AMP jacks L (MONO) /R, AUX IN jack (Stereo Mini type), PHONES/LINE OUT jack, AC Adaptor jack
Power Supply DC9V: Dry battery (R6/LR6 (AA) type) x 6, AC Adaptor (PSA series: Optional)
Current Draw 120 mA
* Expected battery life under continuous use: Carbon: 3.5 hours, Alkaline: 12 hours. These figures will vary depending onthe actual conditions of use.
Accessories Owner's manual, Dry Battery (Alkaline: LR6 (AA) type) x 6, Roland Service (Information Sheet)
Options AC Adaptor: BOSS PSA series, Foot Switch: BOSS FS-5U
Size and Weight ( incl. batteries )
Width 384 mm 15-1/8 inches
Depth 225 mm 8-7/8 inches
Height 102 mm 4-1/16 inches
Weight 3.2 kg 7 lbs.
* 0 dBu = 0.775 Vrms * AF method (Adaptive Focus method) This is a proprietary method from Roland that vastly improves the signal-to-noise (S/N) ratio of the A/D and D/A converters.
Kjøpte denne for 2500kr og det er knapt blitt brukt.
Så godt som nytt.
Hbo 1800kr.
Svarer på PM og mail ( sierracossie@epost.no ) og kan nåes på tlf ( 95158451 ) etter 24 juni pga offshoretur.
Skulle ønske jeg kunne spille og hadde en gitar =p dette var fett =D
Er det ikke bare å begynne å spille da?
Kjøp deg en gitar og en forsterker så er du good to go da vettu. ;)
