s62 Skrevet Oktober 5, 2009 Skrevet Oktober 5, 2009 Output Power at 14.4V (20Hz ∼ 20kHz): .High Current Mode: 4 x 35W @ 4 ohms (0.04% THD) 4 x 50W @ 2 ohms (0.1% THD) 2 x 100W @ 4 ohms bridged (0.1% THD) 1 ohm stereo / 2 ohms bridged stable .High Voltage Mode: 4 x 75W @ 4 ohms (0.04% THD) 4 x 100W @ 2 ohms (0.1% THD) 2 x 200W @ 4 ohms bridged (0.1% THD) THD: ≤0.005% (1kHz, 4 ohms) Freq. Response: 5Hz ∼ 50Khz (+.05/-.5 dB) Fuse: 40A Dimensions: 12.6" x 10.25" x 2" (32cm x 25.8cm x 5cm) Weight: 7.7 lbs. (3.5 kg.)
glenn.G Skrevet Oktober 7, 2009 Skrevet Oktober 7, 2009 400 +frakt og den er din ok,send meg pm med bet info
