Hei! noen som kan hjelpe meg med dette.
Når jeg skal ha på setevarmere, så bare lyser knappen for setevarmer i to sek før den kutter. Dette gjelder både på førersetet og pasasjer siden.
Da er det meget sansynlig at det er brudd i varme elementet i stolene dine.
Er det brudd i elementet Skal lyset i bryteren blinke i 12 sekunder. Er spenningen under 11,7 volt eller defekte sikringer slukner lampa raskt.
Det er innebygget diagnose i bryterene som viser Hva som er feil;
Note
Current supply to the heat conductor of the seat heating electronics is interrupted if the vehicle battery voltage drops below 11.8 volts. The function LED installed in the switch however remains on. Current supply to the heat conductor is resumed when the battery voltage again reaches 11.8 volts.
Fault monitoring
The seat heating electronics monitors the temperature sensor and the heating elements for faults.
If a break or short occurs at the temperature sensor, the seat heating is switched off in order to prevent overheating.
Fault indicator
If a fault is recognized, the function LED installed in the switch flashes for 12 seconds when the fault occurs, or, if the fault is already present, when the seat heating is switched on.
Flash code
A flash code shows what faults the electronic circuitry has currently detected.
Flash code output is started by following procedure:
•Switch off ignition
•Press and hold the button for seat heating
•Switch on ignition (terminal 15) with button depressed
•Release the button and press it again briefly
The following faults can be indicated:
Flashing
Defect
Once
Switch faulty (potentiometer or electronics) or switch overheating due to a short-circuit
Twice
Temperature sensor has break or short
3 times
All 4 heating elements broken or have a short (probably break or short in wiring harness)
Hadde samme feilen på min.Bryteren lyste i noen sek før den slo seg av. Byttet elementet og det virka etterpå :wink: Ingen blinking av noe slag i bryterene mine. Er vel ikke alle modeller som er utstyrt med innebygget diagnose da?
  • 9 months later...
Hiver meg på denne. Opplever samme feil som trådstarter, i begge setene. Jeg synes dette er rart siden begge har virket for få dager siden, og nå virker ingen. tviler derfor litt på at det er elementene... Har prøvd denne diagnose-testen, men får ingen blink i det hele tatt. Har også prøvd å lade batteriet, uten at det hjalp. Noen som vet hva annet som kan være galt, evt. typiske feil som går igjen?
