pioneer GM-6100F 4 kanals forsterker selges
har en 4 kanals bilforsterker jeg vurder å sell.
ta å kom med et seriøst bud da:p
Key features GM-6100F
Bridgeable 4-channel capability 4 x 120 W or 2 x 300 W (Max. Power)
Continuous output power: 4 x 60 W or 2 x 150 W (4 Ω) 4 x 75 W (2 Ω)
4 x 80 W or 2 x 230 W (4 Ω) DIN Power (DIN 45324, +B = 14.4 V)
Load impedance capability (2 — 8 Ω)
Variable LPF( -12 dB/Oct): 40 - 120 Hz
High Voltage Input capability (200 mV — 6.5 V)
Features GM-6100F
Type Bridgeable Power Amplifier
PWM regulated MOSFET power supply Yes
Channels 4
Load impedance capability 2 - 8 Ohm
RCA terminals Yes (input/output)
Speaker Terminals Screw-type
Power / ground terminals Large screw-type
LPF 40 - 120Hz (Variable)
HPF 40 - 120Hz (Variable)
High voltage input capability 200 mV - 6.5 V
High performance balanced isolator circuit Yes
Specifications GM-6100F
Maximum Output Power 4 x 120 Watt or 2 x 300 Watt (4 ohms)
DIN power output (W)
(DIN45324, +B = 14.4V) 4 x 80 Watt or 2 x 230 Watt (4 ohms)
Continuous power output (RMS) 4 x 60 Watt or 2 x 150 (14.4V (20-20kHz/4ohms))
4 x 60 Watt or 2 x 150 (14.4V (20-20kHz/2ohms))
Frequency response 10 Hz - 50.000 Hz
Distortion 0,010 %
S/N ratio > 95 dB
High Voltage Input Capability 200 mV - 6.5 V
Max. current consumption (A/4ohms) 35 A
Chassis size (W x H x D) 300 x 60 x 327 mm
Unit weight 4.7 kg
