Kraftig forsterker perfekt for RUSSE-VAN!
Dette er en meget kraftig forsterker.
MTX Thunder 92001 er modellnavnet, og spesifikasjonene er som følger:
Amplifier Class..............................D
Number of Channels.....................1 - Mono
RMS Power (4 ohms)....................1000 watts x 1 channel
RMS Power (2 ohms)....................2000 watts x 1 channel
RMS Power (1 ohm)......................3000 watts x 1 channel
Bridged RMS Power.......................N/A
Total RMS Power Output...............3000 watts
Peak Power Output.......................6000 watts x 1 channel
Total Peak Power Output..............6000 watts
Minimum Impedance Unbridged...1 ohm
Minimum Impedance Bridged........N/A
THD at Rated RMS Power..............0.5%
Speaker Level Inputs....................Yes
Preamp Outputs...........................1 pair
Built-in Crossover.........................Low-pass (LP)
High-Pass Crossover Frequency....N/A
Low-Pass Crossover Frequency....40 - 200 Hz
Subsonic Filter..............................20 - 50 Hz
Signal-to-Noise Ratio.....................65 dB
Channel Separation.......................N/A
Bass Boost..................................-12 - 12 dB
Bass/Gain Remote........................Yes
Fan Cooled.................................. Yes
Fuse Rating..................................N/A
Lite brukt og i meget fin stand.
ca 1 år gammel.
Veil.pris ny var ca 16000...!
Selges for kun 5500,-
Gjør ett kupp!
Ring meg på 92443014, eller send en mail på sammigun@hotmail.com
