solgt
Alpine CDA-9854 R selges i Kristiansand.
Dette er topp serien til Alpine lydmessig. Virker sammen med ratt fjern styringen til Bmw med adapter fra Audioleads: http://www.nexxia.co.uk/products.asp?ca ... AR%20AUDIO
Adapter plate for erstatning av original stereo: http://www.nexxia.co.uk/product.asp?pro ... a&section=
4X50 Watt,MP3/WMA,IPOD Adapter,3-Linje utganger++
selges for 999 kr ferdig priset
http://www.bilstereoboden.no/html/produ ... duct_list=
Det følger med Adapter for å montere spiller i følgende BMW:
3-serie (E36/E46) 1991-2005
5-serie (E34/E39) - 1988-2005
7-serie (E32/E38) 1982-1994
8-serie (E31) 1990-2000
Z3 (E36) 1996 ->
..og ekstra adapter for Toyota.
Alpine CDA 9854R - radio / CD / MP3 player specifications
• General
• Product Type Radio / CD / MP3 player
• Recommended Use Car
• Form Factor Full-DIN - In-dash unit
• Width 7.0 in
• Depth 6.4 in
• Height 2.0 in
• Weight 3.5 lbs
• Faceplate Type Detachable
• Audio System
• System Control Bus Ai-NET
• Sound output mode Stereo
• Remote control Optional
• Audio system controls Mute , Volume , Bass , Subwoofer level , Treble , Loudness , Balance , Fader
• Amplifier max output power / channel qty 50 Watts x 4
• Display illumination color Green , Blue , Amber , Red
• Button backlight color Red
• Audio system CD changer control Yes
• Clock Yes (digital)
• Additional features Night dimmer , ID3 tags support , CD Text capable , IPod ready , Rotary encoder multi-control
• Radio
• Type Radio tuner - AM/FM
• Tuner frequency range AM: 531 - 1602 kHz , FM: 87.5 - 108 MHz
• Station preset qty 30.0
• AM station preset qty 12.0
• FM station preset qty 18.0
• Radio signal-to-noise ratio 65.0 dB
• RDS Yes
• Supported RDS functions PS , EON , PTY , TP , PI , TA , AF
• Additional radio features DX/LO switch , Station naming
• CD System
• CD system type CD / MP3 player
• Playback modes Repeat folder , Repeat all , Intro scan , Random play / shuffle
• Digital audio standards supported MP3 , WMA
• CD system response bandwidth -19995.0 Hz
• Signal-to-noise ratio 105.0 dB
• CD system total harmonic distortion 0.008%
• CD system dynamic range 95.0 dB
• CD-R compatible Yes
• CD-RW compatible Yes
• Connections
• Connector Type 1.0 x Front channel output ( RCA phono x 2 ) , 1.0 x Rear channel output ( RCA phono x 2 ) , System components control bus , 1.0 x Subwoofer output ( RCA phono x 2 )
Ring Ronny 41769595
Hva er grunnen til at du selger? Alt virker 100%?
Tar den om den er 100% og du kan sende i oppkrav, mot at jeg betaler selvfølgelig.
den har en multi utgang bak hvor du kan velge mini jack eller i ipod styrings kabel som tilbehør. Da styrer du hele ipoden fra headuniten,
