Hei, har en forsterker ståans som jeg ikke bruker, og tenkte derfor jeg kunne selge den. Kom med bud!
Forsterkeren er støvete og jævelig på bildene :)
Litt copy - paste:
FEATURES:
- Multi-Function System Management Panel Enables you to easily tailor the characteristics of the signal to your audio preferences
- Stylish end caps fit seamlessly to protect connections, terminals and the heat sink against alien objects and create clean lines for clean installations
- Screw Down Connectors ensure a secure bond between components in the audio system
- Thermally Dynamic Heat Sink, efficient heat sink structure designed to keep components within accepted heat tolerances
Product Specifications:
Max Current: 105A
Full Rated Power Distortion (Max) 1kHz: 0.04%
THD @ Rated Power 1kHz/100Hz: 0.1%
Channel Separation: 50
Frequency Response Hz (-3dB): 10Hz - 40Hz
Signal to Noise: >90
Variable High Pass Filter: 12 dB/Octave
Variable Low Pass Filter: 12 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47Kohm
Fuse Rating: 35A x 3
Power terminals accept: 25mm²
Maximum Power @ 14.4VDC: 1000 Watt
RMS Power: 150 Watt x 4 Channel @ 4 Ohm
220 Watt x 4 Channel @ 2 Ohm
440 Watt x 2 Channel @ 4 Ohm Bridged
Fysiske mål:
Lengde: 506mm
Bredde: 278mm
Høyde: 59mm
