Endre Hånde Skrevet Juni 8, 2010 Skrevet Juni 8, 2010 Link til samme forsterker type, bare sort: http://cgi.ebay.ie/Sony-TA-FA30ES-Audio ... 0414743643 Høytalere: http://www.amazon.com/dp/B000FYZARY/ref ... B000FYZARY TA-FA30ES Technical Specifications System Power Amplifier: Pure-Complementary SEPP MOS FET power amplifier with all stages directly coupled Preamplifier: low-noise ,high-gain equalizer amplifier Power Section: Large-capacity power supply advanced STD Rated Output 4 ohms, 120 W + 120 W (DIN 0.7%) 8 ohms, 80 W + 80 W (DIN 0.7%) Speakers Impedance 4 to 16 ohms Output Bandwidth (8 ohms) 10 Hz to 100 kHz (at 40 W output, and high-frequency distortion rate of 0.08%) Total Harmonic Distortion 0.008% (at 8 ohms, 10 W output) Damping Factor 100 (8 ohms, 1 kHz) Intermodulation (IM) Distortion (60 Hz : 7 kHz = 4 : 1) 0.008% (8 ohms) Throughrate 125 V / μsec, 250 V / μsec (Inside) Residual Noise Less than 100 μV (network A) Equalizer Deviation Phono MM: 20 Hz to 20 kHz, +/- 0.5 dB Frequency Response Tuner, CD, Aux, Tape1/DAT, Tape2/MD: 7 Hz to 100 kHz +0/-3 dB S / N Phono MC: 78 dB (network A, 0.5 mV) Phono MM: 95 dB (network A, 0.5 mV) Tuner, CD, Aux, Tape1/DAT, Tape2/MD: 105 dB Inputs Input sensitivity and impedance Phono MC: 0.17 mV, 100 ohms Phono MM: 2.5 mV, 50 kilohms Tuner, CD, Aux Tape1/DAT, Tape2/MD: 150 mV, 20 kilohms Maximum input capability (1 kHz) Phono MC: 9 mV Phono MM: 150 Mv Outputs Output level/impedance REC OUT 1, 2: 150 mV, 1 kilohm PHONES: 10 mW (at 8 ohms) Tone Controls Bass (100 Hz): +/- 7 dB Treble (10 kHz): +/- 7 dB General Power requirements 230 V AC, 50/60 Hz Power consumption 220 W Dimensions (approx.) (w/h/d) 430 x 150 x 415 mm incl. projecting parts and controls Mass (approx.) 11.00 kg Total Boxed Product Weight 14 kg Høytalere: Product Features 1" pure titanium dome tweeter for exceptional high frequency performance 3/4" Mylar-dome, cast-frame chassis mounted in a bi-radial horn for better high frequency repsonse Aluminum waveguides provide better dispersion and a larger listening sweet spot Freeflow port technology delivers great sound and makes sure you get the lowest amount of distortion Technical Details Brand Name: JBL Model: L830 Color Name: Black Speaker Type: Speaker Speaker Amplification Type: Passive Speakers Maximum Output Power: 300 Watts Speakers Response Bandwidth: 48 - 40000 Hz Speaker Connectivity: Wired Depth: 12.6 inches Height: 1.27 inches Width: 0.72 inches Weight: 22.0 pounds Stativ: Ser for meg 2500.- for høytalere og stativ og 2000.- for forsterkeren. Bud kan vurderes, men husk at dette er VELDIG gode komponenter som spiller utrolig bra! FOrsterkeren er den siste gode forsterkeren fra Sony. Dette er ES Serien. (eller GULL serien som den ble markedsført som)
Endre Hånde Skrevet Juni 8, 2010 Forfatter Skrevet Juni 8, 2010 Forsterkeren ligger ute med minstepris på 1500 her: http://avforum.no/avtorget/showproduct. ... 825&cat=13 Høyttalerne kommer opp også, men avforum var sinnssykt tregt idag.
Endre Hånde Skrevet Juni 11, 2010 Forfatter Skrevet Juni 11, 2010 Kom med bud. Dette er mildt sagt et kjempe anlegg for de som setter pris på GOD lyd!
