ibux Skrevet Juni 9, 2010 Skrevet Juni 9, 2010 KdFi BMW M50 *BOLT ON !OBS! IKKE VANOS Programmable PNP EFI The kdFi V1.3 is mounted and wired in a Motronikhousing and loaded with an initial setup for M50 engines. Customer to do: - Replace Throttle Position Switch with Throttle Position Sensor (not included in delivery) - Change Engine Management - START ENGINE ! Features: - Alpha-N setup (changeable via Software to MAP for charged engines) - Air flow meter is not needed any more - full compatible to MSextra Software (Megasquirt) - free Software / Open Source - MS2 onboard / Firmware MS2extra - Fuel Table 16x16 - Ignition Table 12x12 - USB Conector - Widebandlambdacontroller JAW on Board (JAW Prozessor not included) - Upgradeable up to 8 single coils (option) - Knocksensor Input (option) - programmable relais output (option) - elektronic boost control (option) - Barometric correction (option) - CAN Bus (option) Selges Kr: 6000 Kontakt må Gjøres på TLF :93854023 Har Blitt kjøpt på KSR.no De kan være behjelpelig
Azeton Skrevet Juni 10, 2010 Skrevet Juni 10, 2010 Skjønner ikke hvorfor du skal skifte ut TPS.. For M50 har Sensor og ikke switch!
