S: Soundstream anlegg selges - Forsterker + sub
Forsterker 1:
Soundstream PCA 2.520
(Den minste av dem)
Technical Specification
RMS Power Range : 160-260 Watts
Number Of Channels: 2
Maximum Power: 520 Watts
Low Frequency response: 10 Hz
High Frequency Response: 30000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
No. OF CHANNELS: 2
OUTPUT (watts):RMS @ 4 Ohms 160x2
RMS @ 2 Ohms 260x2
RMS @ 4 Ohm Mono 520x1
T.H.D.: 0.02%
FREQ. RESPONSE (Hz): 10 - 30k
SIGNAL TO NOISE RATIO: >97dB
DAMPING FACTOR: >200
INPUT SENSITVITY: 0.5 - 4.0V
CROSOVER SLOPES: 12dB
CROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600
Low-Pass(Hz) 50 - 150
SUBWOFFER EQ: 0 - 18dB 0
SUBWOOFER EQ FREQ. (Hz) : 40 - 120
DIMENSIONS (INCHES): 9.5x2.5x15.0
Fully regulated MOSFET power supplies
PWM circuitry
Tri-guard amplifier protection
IDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
Platinum RCA inputs and outputs
Line Outputs
Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
Continuously variable high and low-pass crossovers
Variable subwoofer equalizer
Phase inversion switch (0 - 180)
OEM floating ground input
Platinum 4-gauge power connectors
Tri-mode operation
Optional Remote Bass Control (EGA-RM)
Forsterker 2:
Soundstream PCA 2.760
(Den største)
RMS Power Range : 220-380 Watts
Maximum Power: 760 Watts
Features
No. OF CHANNELS: 2
OUTPUT (watts):RMS @ 4 Ohms 220x2
RMS @ 2 Ohms 380x2
RMS @ 4 Ohm Mono 760x1
T.H.D.: 0.02%
DIMENSIONS (INCHES): 9.5x2.5x20.0
PWM circuitry
Line Outputs
Tri-mode operation
Sub:
T5-12
* Sensitivity: 84.9 dB
* RMS Power Range : 900 Watts
* Impedance: Dual 2 Ohm
* Low Frequency response: 30 Hz
* High Frequency Response: 300 Hz
* Diameter: 12 Inch
Features
* Cast Aluminum Basket
* Hand Laid Pulp Paper Cone
* One Piece Gasket/Tall Rubber Surround
* Large PP Injected Dust Cap
* Dual Stacked Magnet Assembly (Triple Stack on T5-15)
* Dual 2 Ohm 3� Aluminum Voice Coil
* Vented Back Plate
* Integrated Tinsel Leads
* Nickel Plated Push Terminals
* Durable ABS Plastic Motor Cover
Den minste forsterkeren er noe brukt, men fremstår fremdeles som meget bra. Ikke "merkbart brukt"... Den største forsterkeren + sub er ubrukt, og klar til å få en nye eier.
Priser:
PCA 2.520 - 1400kr
PCA 2.760 - 1900kr
T5-12 - 2000kr (http://www.finn.no/finn/torget/tilsalgs ... e=23299858 selges for 3.790kr på Finn av en forhandler)
Send meg gjerne en PM om du er interessert :)
En kommentar om Soundstream fra AVforumet:
"Soundstream er vel absolutt noe av det bedre du kan putte i en bil, hvis jeg ikke husker feil så er vel Soundstream en del av Harman konsernet, og det skulle ihvertfall borge for god kvalitet.
Har selv hatt forsterkere og høyttalere fra Soundstream og de produktene var ihvertfall jeg veldig godt fornøyd med."
