Rockford Fosgate T400-4 selges
Selger en nesten ikke brukt rf forsterker, tye rf t400-4
selges til hb over 3000
info:
Number of Channels 4
Rated Power
(RMS Continuous Power) 60 Watts x 4 @ 4-Ohms
100 Watts x 4 @ 2-Ohms
200 Watts x 2 @ 4-Ohms Bridged
2-Ohms x 2 Bridged Stable
Total Power
(Sum of Rated Power) 400 Watts
Dynamic Power
(PVC/PowerCube® Measurement) Front Channels
90 Watts x 2 @ 4-Ohms 0° Res
154 Watts x 2 @ 2-Ohms 0° Res
Rear Channels
Bridgeable Yes
Efficiency (average) 69% @ 4-Ohm
68% @ 2-Ohm
Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output n/a
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch EQ
(overrides rear channel built-in Punch EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1dB
kan nåes på 95807854
