bmw e39 520i feil kode 1245 EGS
kan noen gi meg forslag på hva jeg kan gjøre her.
This code is stored when a short to ground occurs on the wire
from the EGS to the DME control unit,for more than 2.5
seconds. The on-board computer should display the message
TRANSMISSION EMERGENCY PROGRAM.Ignition timing
will be retarded only once and then the DME will substitute the
original value until this code is cleared. Check the wire and
connection to the EGS.
