Pitstop Skrevet Januar 13, 2011 Skrevet Januar 13, 2011 Hei Skal selge et ubrukt frontsett av type blaupunkt velocity vrx-170. 2-veis komponent 165 mm Diameter Maksimal effekt 140W RMS Følsomhet 93 dB 1000 kr Har også en lite brukt 4-kanals harman produsert Infinity Reference 7541a •4-channel car amplifier •111 watts RMS x 4 at 4 ohms (139 watts x 4 at 2 ohms) •278 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode) •front and rear variable high-/low-pass filters (32-320 Hz, 12 dB/octave) •variable bass boost (0-12 dB at 50 Hz) •MOSFET power supplies •CEA-2006 compliant •Tri-way capable (Tri-Way crossover required) •preamp- and speaker-level inputs •preamp outputs •8-gauge power and ground leads with a 60A fuse recommended — wiring and hardware not included with amplifier •fuse rating: 30A x 2 •16-3/8"W x 2-11/16"H x 12-1/8"D 1800 kr http://www.crutchfield.com/S-ajLAxg5N52 ... 7541a.html _________________ E60 M-Tech viewtopic.php?f=6&t=149514 E46 320cd M-tech http://www.bimmers.no/viewtopic.php?t=131788&highlight= E30 M20 3,2 dbilas M-tech2 http://www.bimmers.no/viewtopic.php?t=52214&highlight=
