Hei
Har ett GoPro motorsport Hero HD sett tilsalgs
Kamera er helt nytt i uåpnet pakning
Det følger med diverse utstyr til å feste kamera til bil, båt, motorsykkel og alt annet man føler for :D
Se bildet under.
Dette er ett genialt kamera som lager film i meget bra kvalitet selv i stor fart og mye bevegelse.
Jeg selger kamera for 2500,- + frakt
Det eneste man trenger for å starte filmingen er ett SDHC minnekort.
Under litt info fra http://www.gopro.com
Mvh
Stian
What’s Included:
* 1 HD HERO Camera (5 megapixel)
* 1 Rechargable 1100 mAh Lithium-Ion Battery
* 1 Waterproof Quick-Release Housing (180’/60 m)
* 3 Flat, 3M™ Adhesive Mounts
* 2 Curved, 3M™ Adhesive Mounts
* 2 Quick-Release Buckles
* 1 Vertical Surface “J-Hook” Buckle
* 1 Suction Cup Mount
* 1 Three-Way Pivoting Side Arm Assembly
* 1 USB Cable
* 1 Component Video (HDTV) Cable
* 1 Composite Video + Audio Out Cable
* Warranty: One Year
Tech Specs:
Camera Optics
* Lens Type: Fixed Focus (2ft/.6m – ∞), glass
* Aperture: f/2.8 (high performance in low-light situations)
* Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
* Angle of View: 127º wide angle in 1080p mode
Video
* HD Video Resolution Modes: (subject to change, pending final firmware release)
o 1080p = 1920×1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
o 960p = 1280×960 pixels (4:3), 30 fps, 12 Mbit/s data rate
o 720p = 1280×720 pixels (16:9), 60 fps, 15 Mbit/s data rate
o 720p = 1280×720 pixels (16:9), 30 fps, 8 Mbit/s data rate
o WVGA = 848×480 pixels (16:9), 60 fps, 8 Mbit/s data rate
* Sensor Type: 1/2.5″ HD CMOS, 2.2µm-sized pixels
* Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
* Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
* Exposure Control: Auto with user selectable center weighted average and spot metering settings
* White Balance: Auto
Audio
* Microphone: Built-in, mono with AGC (automatic gain control)
* Audio Format: 48 kHz, AAC audio compression
* Resolution: 5 megapixel
* Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
* Memory: SD card (SDHC), up to 32GB capacity (not included)
* Average recording times (using 32GB SD card):
o 1080p (30 fps): 4h 21m
o 960p (30 fps): 5h 26m
o 720p (60 fps): 4h 21
o 720p (30 fps): 8h 09m
o WVGA (60 fps): 8h 09m
Camera Connectors & Cables
* PC Connection: USB 2.0 (data connection and battery charging)
* HDTV Out: HD NTSC & PAL (component cable incl.)
* Audio Out: Combo 2.5mm jack with stereo audio and composite video out
* PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
Power & Battery
* Battery Type: Rechargeable 1100 mAh lithium-ion
* Battery Life: Approx. 2.5 hrs
* Charging: via USB to computer or optional power adapter
* Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
* Depth Rating: Up to 180 feet / 60 meters
* Construction: Polycarbonate and stainless steel
* Hardware: Stainless steel
Size & Weight
* Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
* Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
Er på utkikk etter felger til E30, så kan betale med kamera og melomlegg om noen har noe som frister.
Har som utgangspunkt 3 delte 8,5 eller 9x17 fremme og 10x17 bak. Helst OZ Mito, Futura, Hartge design D eller lignende.
Kom med forslag. Må ikke være 4x100 da jeg leker med tanken på å bygge om til 5x120.
Stian
Intr i å bytte i noe annet til E30 da? ;D
Har Sperrediff og 40/60 senk
Kan være intr i E30 ting ja, men sperrediff har jeg, og senkefjærer er ikke intresant.
Kan være interesert i omb deler til 5x120, Z3 tannstang, coilovers, pris kan vi bli enig på PM om noen har.
Har også 32GB Sandisk minnekort jeg kan selge med. Da er det bare å feste kamera på bilen å drifte til dekken er vekk :wink:
