Stian Børresen Skrevet April 4, 2011 Skrevet April 4, 2011 Har 2 pent brukte 1-2kanaler til salgs. Har også 2 pent brukte TypeR 12" subber i kasse til salgs. 1. Alpine V12 MRV-1507 - En meget kraftig forsterker! 2. Alpine V12 MRV-T407 - Kraftig litt mindre forsterker! 3. Alpine TypeR 12" subber Dette selges til en fornuftig penge, kom med bud: ) Alt fungerer som det skal og subbene spiller utrolig bra med den største v12 forsterkeren. Ta kontakt på PM,mail eller telefon: stian.b0rresen@gmail.com 97010308 Forsterker 1: MRV-1507 24 dB / Octave LP / 12 dB / Octave HP Continuously Variable Crossover (30-200 Hz) 1-Band Parametric EQ (30-200 Hz) Subsonic Filter (15 Hz) Extra Large Gold Plated Terminals with Wire Insert Capability Top Panel Power LED 4V Input Capability 1-year SonicElectronix.com warranty Specifications: Amplifier Type: 2-channel RMS Power: 150W x 2 @ 12V Bridged RMS Power: 600W x 1 @ 12V THD at Rated RMS Power: 0.08% Speaker Level Inputs: No Preamp Outputs: Yes Built-In Crossovers: HP/LP Bass Boost: 12 dB Frequency Response: 10-50,000 Hz Channel Separation: n/a Signal to Noise Ratio: 105 dB Fuse Rating: 80A amps Forsterker 2: MRV-T407 Specifications: Dividing Network : 50Hz-200Hz HP/LP (12dB/oct) Foot Print (WxHxD)in : 7-1/8O x 11O x 2-3/8O Foot Print (WxHxD)mm : 180mm x 280mm x 60mm Frequency Reponse : 10Hz - 50kHz (+0, - 1dB) Heat Sink (WxHxD)in : 7-1/8O x 10-1/4O x 2-3/8O Heat Sink (WxHxD)mm : 180mm x 260mm x 60mm Input Impedance : 10k ohm Input Sensitivity (for rated power) : 200mV ~ 4.0V Power Requirements : 14.4V DC (11V to 16V) Signal to Noise (S/N) : 100dBA (referenced to rated power) Slew Factor : greater than 5 Speaker Impedance : 4 or 2 ohms(stereo), 4 ohms(bridged) MAX Power (at 14.4V,EIAJ) Bridged 4 ohms : 400W x 1 Per channel into 4 ohms : 140W x 2 RMS Power (at 12V,20Hz-20kHz) Bridged 4 ohms : 150W x 1 (0.3% THD) Per channel into 2 ohms : 75W x 2 (0.3% THD) Per channel into 4 ohms : 40W x 2 (0.08% THD) RMS Power (at 14.4V,20Hz-20kHz) Bridged 4 ohms : 200W x 1 (0.3% THD) Per channel into 2 ohms : 100W x 2 (0.3% THD) Per channel into 4 ohms : 60W x 2 (0.08% THD) Alpine TypeR 12" x2 (dual voice coil subber): *Kevlar®-infused pulp cone *1" Santoprene rubber surround *dual 4-ohm, 2" voice coils *frequency response 24-1,000 Hz *power range 100-300 watts RMS (150 watts RMS per coil) *peak power handling 1,000 watts *sensitivity 87 dB *top-mount depth 6-15/16" *sealed box volume: 0.7-1.0 cubic feet *ported box volume: 0.75-1.75 cubic feet *Recommended Q-Logic Box Type: 1
Stian Børresen Skrevet April 4, 2011 Forfatter Skrevet April 4, 2011 Tja, på hvilke av tingene?: ) Er noe usikker på prising på forsterkerne, så har satt bud for å se hva folk mener de er villige til å betale for dette. Det er jo tross alt kvalitetsforsterkere begge 2 der den ene er oppgitt flere plasser til 900wrms - noe som burde holde evig lenge til det meste av subber. Er innebygd equalizer oppe på forsterkeren med flere justeringsmuligheter.
