Vis i appen
solgt
Fremhevede svar
Ksport Circuit Pro Coilovers til E36.
Spesial bestilt av GS bildeler.
Må ikke forveksles med "vanlig" Ksport.
Ett skikkelig gromt kit.
Bound og rebound kan justeres separat
i 864 forskjellige innstillinger.
Kun vært prøvemontert.
Ny pris 24000kr
selges 12000kr
ring for info: 97766945
TÜV papirer?
Dette så skikkelig gromt ut ! Har utrolig god erfaring med K-sports kit, men kan ikke si jeg har sett dette fra før.. Kan ikke være mange av dette slaget rundt omkring, med separate reservoarer osv...?
Mvh Martin J.
Circuit Pro Damper System
KSport’s Circuit Pro Damper System provides the ultimate in adjustability for enthusiasts and professionals alike, who are wishing to have the maximum in performance and durability. With years of engineering, testing and development, the Circuit Pro Damper System has been perfected in virtually every facet of motorsports, ranging from drifting to time attack or circuit driving. The uncompromising range of adjustability on the Circuit Pro Damper System makes it possible to win at the track, yet drive daily on the street as well.
The key component to the Circuit Pro Damper System is its utilization of remote reservoirs that provide separate adjustments for rebound and compression, as well as nitrogen gas pressure. With over 860 possible settings provided by each Circuit Pro Damper System, it is possible to leave no stone unturned in the quest for ultimate performance from your vehicle’s suspension system. In addition to adjustability, the added oil capacity provided by the remote reservoirs increase the system’s ability to dissipate heat, which leads to improved performance over long periods such as endurance or tarmac racing, in addition to consistent performance throughout long heat cycles. These features, paired with 55mm monotube shocks, ensure maximum durability and consistent performance.
A variety of external hardware components are available on the KSport Circuit Pro Damper System to completely customize the system to your vehicle. When fitting this kit to your vehicle, upper mounts are available in rubber form, pillowball or KSport’s award winning advanced pillowball mounts that offer camber and caster adjustment. Each KSport Circuit Pro Damper System has been dyno tested individually, and the results are included with the system at the time of purchase to aid in damper
Konto
