Hei.
Har eit problem med Nøkkelen te bilen min BMW 320 E90 2008 mod Stasjonsvogn.
Det går ikkje an å låse bilen med Fjernlåsinga på noen av nøklane mine, men går an å bruka nøkkelen i nøkkelhullet..
E da noe eg må gjera får å prog. nøkkelen te Fjernstyringa att ?
Eller Burde eg senda bilen inn ? er vel garanti på bilen enna,, sjøl om den e Importert ?
Hei.
Les på instrulsjonsboka om hvordan du reprogrammer nøkkelen. Har du kun en nøkkel???
Dette er for 2004 320D: Prøv på din bil.
BMW 3-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
Holder en stor knapp på antenneforsterkeren.
Hvit boks under spoileren på bakluka.
Den er sikkert våt og grønn av irr i kontaktene.
Det er veldig enkelt å sjekke.
Hei
Har mer eller mindre samme problem;
Fjernkontrollen fungerer bare periodevis til å låse døra opp/igjen.
Den gode gamle nøkkelen som er gjemt inni "fjernkontrollen" fungerer som den skal i dørlåsen, når fjernkontrollen er "død".
Er det ikke mulig å bytte batteri på disse nøklene? Hva koster batteribytte hos BMW?
Varmetrådene i bakruta fungerer bare av og til.
Dette med antenneforsterkeren er sikkert et godt tips..
Men.. hvordan finner jeg denne hvite boksen?
Åpner jeg "bremselyset" under baklukespoileren?
Eller må jeg skru av andre ting?
Flott om du gadd å lage en liten DIY på dette for meg :-)
