Kenwood 12" subwoofere med kasse (selges/byttes)
Heisann :)
Tenkte jeg vil selge mine subber. Det er dobbel lukka kasse med 12" kenwood.
Kjøpt for en måned siden. Har ikke bruk for de lengre. Kan selges for et greit bud, eller byttes i touch telefon.
1200 Watt maks. inngangs effekt.
Diamond-arry pattern diaphragm
Dobbelt ventilasjons systen
Kraftige Push terminaler
Avtagbar og Vendbar monteringsring
Spesifikasjoner:
300mm P.P.Cone with fiber texture
Diamond Array Diaphragm
1200W Maximum Input Power
Dual Ventilation System
Rubber surround
Push Terminals
Reversible gasket
Høyttaler:
Speaker Type: Subwoofer
Peak Input Power 1200W
Rated Input Power 400W
Speaker Size 300mm
Speaker Cone Design Diamond-Array pattern
Magnet Type Ferrit
Terminals Silver-plated Push Type
Dual Ventilation System Yes
Speaker cover Yes, as part of dual ventilation system
Gasket Installation two-sided
Installation Capabillity Sealed/ Ported
Høyttalerspesifikasjoner:
Maximum Input Power 800W
Woofer Cone material Injection P.P. Cone
Speaker Basket Steel
Speaker Surround Rubber
Sensitivity 85dB/W/m
Frequency Response 34Hz ~ 300Hz
Subwoofer Impedance 4Ω x 1
Dimensions (W x H x D) 326 x 326 x 170.5mm
Mounting Depth 153mm
Mouting Hole Diameter Ø 282mm
Speaker Weight 6300gr
Weight of Magnet 1780gr
Subwoofer Parameters:
Nominal impedance (Z) 4Ω
DC resistance (Re) 3.4Ω
Resonant frequency (FSO) 25Hz
Mechanical Q factor (QMS) 8.25
Electrical Q factor (QES) 0.91
Total Q factor (QTS) 0.82
Voice coil inductance (LBM) 1.65mH
Voice coil diameter (d) 65mm
Force factor (BL) 10.5T/m
Peak excursion Xmax 15.1mm
Moving mass (MMS) 183gr.
Volume accoustic compliance (VAS) 83.7liter
Piston Area (SD) 0.051m²
Displacement 2155cc
Sealed box volume 35.4liter
Sealed Box Dimensions 475 x 362 x 299mm ( 19mm thick MDF)(WxHxD)
Vented box volume 56.6liter
Vented Box Dimensions 590 x 362 x 355mm ( 19mm thick MDF)(WxHxD)
Port dimensions (labyrinth) (W x H x L) 38 x 324 x 546mm
