http://www.facebook.com/photo.php?fbid= ... e=1&ref=nf
ENGINE:
Remapped ROM (Daiichi Speed)
Engine Room Painted Silver
HKS GT RS Turbo
Custom Top Mount Manifold
Aftermarket Downpipe & Frontpipe
Nismo 555cc Injectors
Aftermarket Engine Mounts
Metal Suction Pipe
HPI Induction Filter
Custom Intercooler and Piping Kit
Z32 AFM
Samco Rad Pipe
Aftermarket Fan Pulley
Dual Oil Catch Tank Setup
Master Cylinder Helper Block
SARD Adjustable Fuel Pressure Regulator
Large Metal Radiator
Greddy Rad Cap
Aftermarket Catalyser? (Would need removed to confirm whats in it)
Kakimoto Racing GT 1.0Z Exhaust System
Oil Cooler
Stain Mesh Turbo Oil Line
SUSPENSION / BRAKES / WHEELS / DRIVE
Aftermarket Clutch
Aftermarket LSD
Volk GT-C Alloys (Front 17', Rear 18 x 10J +19)
5 Stud Hubs F/R
4 Pot Silvia Brakes (Front)
Aftermarket Tie Rods and Ends
Stainmesh Front Brake Flexis
Racing Gear N1 Circuit Spec Coilovers with Camber Adjustable Pilo Uppers
Nismo Front Lower Arms with Additional Custom Plates / Welding / Bracing
Rear Member has Additional Custom Plates / Welding / Bracing
Nismo Power Brace (Front Member)
Aftermarket Mission Mount
Cusco Rear Adjustable Upper Arms
Aftermarket Rear Member Collars
Nismo Rear Lower Arms with Additional Custom Plates / Welding / Bracing
Hicas Canceller Bar
Ikeya Formula Front Pilo Tension Rods
Rear Wheel Spacer Kits
BODY / EXTERIOR
D-Max Front FRP Wide Vented Fenders
D-Max FRP Vented Bonnet
G-Corporation Style Rear Over Fenders
Carbon Door Mirrors
D-Max Front Bumper
Wise Square One-piece Canards / diffuser (Front)
FRP Rear Diffuser
Carbon Rear Cannards
Uras Front Bumper Indicator Lenses
Uras Front Bumper Side Repeaters
Foam Filled Chassis / Sills (For Rigidity)
INTERIOR
Painted Silver
Thrash Racing Full Bucket Seat (Quite Small)
Nardi Steering Wheel
Custom Carbon Coated Centre Console
Weld Engine Start Button
Blitz ID Boost Controller
Greddy Electronic Oil Temp Meter
Greddy Electronic Water Temp Meter
Sabelt 4 Point Harness
Aftermarket Shift Knob
7 Point Roll Cage + Side Bars
C-Pillar Brace
http://www.facebook.com/photo.php?fbid=10151014034690309&set=o.323488161032805&type=1&ref=nf
ENGINE:
HKS GT RS Turbo
Metal Suction Pipe
Z32 AFM
Samco Rad Pipe
Greddy Rad Cap
Oil Cooler
Aftermarket Clutch
Aftermarket LSD
5 Stud Hubs F/R
Hicas Canceller Bar
BODY / EXTERIOR
Carbon Door Mirrors
D-Max Front Bumper
FRP Rear Diffuser
INTERIOR
Painted Silver
C-Pillar Brace
Såppas, hmm...skal sjekke opp litt;)
hva er feilen med motor?
Litt usikker faktisk... Får aldri surra meg til og gjøre noe med det heller :/
Men på diagnose viser det noe med tomgangsreguleringen?
Går motor ujevnt ved gasspådrag, eller bare merker du ikke full effekt er der?
Er vell ikke gått i noe nød modus og sperrer i en viss hastighet?
