BmwKlovn Skrevet Februar 3, 2013 Skrevet Februar 3, 2013 Selger Holley Red bensinpumpe brukt noen turer. Tumble Polished Billet Look New Lower Housing Casting for Enhanced Fuel Flow and Quieter Operation Maximum Pressure Is 7 PSI Motor Draws 2 Amps Current 7 1/2 Amp fuse recommended Constant Fuel Flow with No Pulsation Improved design for street/strip applications Distinctive “RED” logo Flows 97 GPH (free flow) Flows 71 GPH at 4 PSI Regulator is not required Has externally accessible pressure relief valve (max 7 PSI) Rotor/Vane pump design is more tolerant of contaminated fuels Weighs only 2.88 lbs Includes mounting bracket Repair kits are readily available Can be serviced from the pump end NOT compatible with alcohol or methanol fuels Use of safety shut-off switch, P/N 12-810, strongly recommended - BUD PM -
