Johannes1993 Skrevet April 12, 2013 Skrevet April 12, 2013 Har et problem med en 316i E46, er en 99 mod tror jeg, M43B19 Probleme er at den har vertkresjet en gang så får noen feilmeldingen i aircon, tankmåler ++ Det største problemet er at den tapper strøm når den er av.. MED Mindre, Aircon står på 3.. så noe er vertfall galt der, EWS -> 0F/3F - Power on reset 03/01 - Toleration of changing code increased, key 0ABS -> 21/FB - Wheel speed sensor front right trigger signal 11/00 - Wheel speed sensor front left trigger signal 22/01 - Wheel speed sensor front right continuityA/C -> 11/42 - Relay Rear window defoggerSRS -> 12/8A - Fault lamp (AWL) 1A/A2 - Seat occupancy recognition 1 (SBE1) 11/20 - Power supply 0B/20 - Battery, positive terminal isolation 1 0B/10 - Battery, positive terminal isolation 1 01/C0 - Airbag, driver 1B/04 - Crash telegram memory 06/42 - Side airbag, front right 0A/42 - Head airbag (ITS), front rightIKE -> 8C/C4 - Voltage supply, terminal R, faulty 87/81 - Body bus (K-bus) D7/E1 - Tank sensor 2 F4/88 - No CAN message C7/E1 - Tank sensor 1LCM -> 1F/01 - Activation, motor for HVAC 1 20/01 - Activation, motor for HVAC 2 22/21 - HVAC, front load sensor, short circuit to groundZKE -> 3A/21 - Wiper: Relay Pump or Wire for Headlight cleaning system 3D/04 - Central locking system: Short circuit or Open circuit at Motor Tailgate 01/01 - Wiper: Fuse for Pump, Interior light, Customer cut-off Shadow-memory: 90/3F - Battery Voltage: Open circuit 91/01 - Crash: was activatedSZM -> 09/01 - Heating surface Seat heating right, Open circuit 02/02 - Seat heating left, Short circuit or Open circuit Shadow-memory: 05/3F - Seat heating Lower voltage recognisedGR2 -> 21/01 - Error Togglebit
Johannes1993 Skrevet April 13, 2013 Forfatter Skrevet April 13, 2013 noen som har hatt lignende problem? :S
