///frank Skrevet April 27, 2013 Skrevet April 27, 2013 Ny og rå lykt på 85w HID. Info: 85W HID rechargeable Torch Power output 45W/65W/85W/SOS (4 Modes) Brightness 4200LM(45W) 6000LM(65W) 8500LM(85W) Color temperature-6000K Optical efficiency-100LM/W Bulb life span-3500hrs Battery-8700mAh Irradiation range-over 2 km Continual illuminate time 150mins (45w) 120mins (65w) 100mins (85W) Length-385mm Diameter of bulb holder-80mm Diameter of holder-50mm Material Aerospace-Grade Aluminum alloy (6061-T6) Surface treatment Flat Silver Type III Hard Anodized Finish Reflector High efficiency, Aluminum alloy Glass lens High temp toughened quartz glass lens Battery life-?500 times Battery charger voltage-12.6 v Charging time-About 5 hours Backup light 1W LED bulit-in battery pack Ballast input voltage-9 ~ 16V Working current-6.2 A Head running temperature-80°C max Color-Black Weight ?including battery)-1350g(8700mAh battery? Weight (including battery and with suitcase)-2.75kg Pakken inkluderer: 1 x Black 85W HID Torch/Flashlight 1 x AC adapter(100-240v) 1 x 8700mAh Li-ion battery 1 x Car charger 1 x Shoulder strap 1 x Yellow lampshade 1 x Instruction manual 1 x Cleaning cloth 1 x Aluminum carry box Pris 1000,-
