  • 4 weeks later...
Just finished engine maintenance for this season: new bearings for rods and crankshaft, new piston rings, modified pistons (special coating, to make pistons last longer and stronger), head gasket totally maintained (new valve seal rings, new valve guide`s and so on), new hex bolt`s for crankshaft, new cylinder head casket, new spurk plugs, new ignition wires, also new electronic boost controller (the boost can be set from the ECU how much and in what time) new set up for ECU. 783hp and 933nm max rpm 6300!
All the best,
Reno
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
Since i have made many modifications during the winter with the car, i will change the price of the car. It will be around 175000NOK.
Modifications what i have made:
1.fuel system upergate:
extra fuel pump
extra fuel tank (custom made)
new fuel lines (suitable for ethanol E85)
extra fuel line AN fitings
new bigger injectors 1700cc(suitable for ethanol E85)
new fuel filters
new triplet (PPF pure performance factory product) for fuel line
2. Front original M-tec II pumper + painting + installation
all original connection fitings
new front panel (painting + installation)
fog lights
turn indicators
3. intercooler pipes modifications + intercooler installation
Because i have install`d the M-Tech II pumper, then i had to modify the cooler pipes.
4.new intake manifold (aluminium custom made)
RSP (it is an company in sweden who made me brand new intake manifold)
new one is stronger, for more boost!
5. brake system upergate
new bias bedal box for brakes (not installed yet, but it will be)
6.new electrical wires
all engine wires are brand new (from engine to ECU, from ECU to fuse box)
new fuse box (one box that will include all the fuses that car needs)
also new wires to front lights
new wires for fuel pumps
samsung 7" tab to show all the necessary info
battery isolator switch to cut of the power
7. engine tune up for ethanol E85 + dyno
Last set up result: 840hp/1023nm @ 1,9bar max rpm 6500
Also i can offer transportation of the car, to norway. Cost of the transport depends of the location.
I will make fresh photos, and add them soon.
  • 3 months later...
up :)
Since the summer is ending, i am up for offers, so if anybody has interest then send me your offer to my pm (also i am still interested of exchange with another car).
Also i will add some pictures :)
post-81330-0-41852100-1439812939_thumb.j
post-81330-0-57011900-1439812963_thumb.j
post-81330-0-22192200-1439812977_thumb.j
post-81330-0-24811000-1439812994_thumb.j
post-81330-0-22023700-1439813013_thumb.j
post-81330-0-67618200-1439813020_thumb.j
post-81330-0-88847700-1439813026_thumb.j
post-81330-0-94002800-1439813038_thumb.j
  • 4 weeks later...
  • 3 weeks later...
