[For Sale] BBS LM Style Rims 19x9.5", Sparco Pro 2000, Sabelt Harness, E39 Alcantara Headliner, M-Steering Wheel, M-Bumper (front), Trunk Liner/Carpet
gump
Hi,
I am a fellow BMW enthusiast from Germany. I will come to the Gatebil event in Rudskogen (Norway) on the 12th of July.
Hence I thought some of you might be interested in some parts which I currently have for sale.
I could bring these to the Gatebil event free of charge.
Just let me know if you are interested. :)
BBS LM Style Replica Rims 19x9.5, 5x120, ET45, 265/30/19 Goodyear tyres.Price 8900,00 NOK.
The rims have a bore of 72,6mm, so if you want to fit them on an E39 you will need special adapter spacers.
I can include such spacers for a surcharge (read further below).
These rims are very light for their size and weight only 21.5kg including a 265 tyre.
All four rims and tyres have the same dimensions.
One advantage is that you can rotate the tyres and get the most tyre life out of them.
Furthermore you will have less understeer and a more neutral handling.
You will also notice the improved grip on the front axle.
The new M5 has 265 and the new M3/M4 has 255 tyres up front from factory!
One rim has a few smaller marks on the outside of the lip from the curb.
All rims have small corrosion marks on the lip due to the weather.
These are not scratches, hence one will be able to get them polished out.
The tyres are Goodyear Eagle F1 Asymetric2 with a 5.5mm deep profile and DOT11.
One tyre was repaired due to a small hole which was caused by a screw.
If the tyres are too large for you, you can also buy just the rims (but I prefer to sell them in a package).
The inner part of the rim is not painted black but in gunmetal which is a very nice shade of grey.
The red hub caps are not part of the sale but I will include them free of surcharge.
Please do not ask me if and how good these rims will fit on any BMW models other than the E39.
I am only familiar with the E39. So if you have an E39 please continue reading:
To mount these rims on an E39 you will need special adapter wheel spacers.
The inner bore of the spacers has to be 74,2mm on the inside and 72,6mm on the outside.
I have three sets of adapter spacers which you can buy for surcharge.
One set is 20mm per wheel, another one 25mm per wheel and the last one 40mm per wheel.
If you have coilovers installed you will need to run 40mm spacers up front to clear the spring.
You will also need to even out the lip of the fender and cut out a piece of plastic from the inner plastic fender liner.
If you don't have a coilover system installed you will need to run 25mm spacers up front to clear the strut of the damper.
You will not need to modify the lip or the plastic fender liner in this case.
In the rear you will need to run either 25mm or 20mm spacers, this is up to you.
You will need to even out the fender lip on the rear in any case. The E39 M5 has an evened out lip from factory already on the rear fender.
I would also suggest to run rear M5 plastic fender liners if your model is not an M5 one, as they provide more space for the tyre.
Sabelt Racing Harness. Price 700,00 NOK
This is an older harness which used to be a six-point one, however I do not have the belt for the crotch area.
But you can still use it perfectly as a four-point harness and you can chop off the part for the crotch belt.
The homologation is obviously not valid anymore. The harness comes with mounting plates and bolts.
It has 3" wide shoulder and hip belts. You will need to invest some time in cleaning up this harness if this is important to you.
Sparco Pro2000 seat. Price 2300,00 NOK.
This seat has no valid homoligation anymore.
It has a very small, barely noticable hole in the cover (see pictures).
The color is a very nice dark blue and is not bleached out.
The seat is a snug fit for persons which are up to 1.85m tall and are weighting up to 90kg.
If you are heavier then 90kg I recommend using the Sparco Evo Plus seat range.
BMW E39 Alcantara Headliner (super rare). Price 8900,00 NOK.
This is a very rare part as it was not even standard on the M5's and had to be optioned!
This is a factory alcantara headliner! This is probably the best option you can choose for your E39.
Your interiour will feel very expensive, luxurious and much cosier once you installed this headliner.
I will also include the hat rack, the rear sun shade and the sun roof panel.
This headliner is in a great condition and comes with all the lights, a-, b- and c-pillar covers, basically all you need (nothing is missing).
BMW E39 E38 M-Steering wheel (covered with new leather not long ago!). Price 1800,00 NOK.
This steering wheel is in a great condition as it was covered in new leather just 20.000km ago.
The leather has still a very nice feel to it and is still matt, not shiny.
This steering wheel will fit any E39, except the facelift.
BMW E39 E38 heated steering wheel. Price 900,00 NOK.
This heated steering wheel should be covered in some new leather as it is very used.
However it is fully functional and includes heating. It will come with the coal pins and slip ring.
It will fit any E39 models up to September '96.
If you get a slip ring and switches from a newer model it will also fit models after September '96.
BMW E39 M-Front Bumper (original!). Price 3600,00 NOK.
This is an original OEM BMW front bumper. It looks like new and doesnt have any scratches on the visible areas.
You just need to sand and paint it. No need to clean inperfections.
This bumper was not repaired previously as it never received any damage.
It took me very long to find such a decent bumper.
If you want you can also buy the black moulding rocker panels with a surcharge (these are brand new).
BMW E39 trunk liners and carpet (very good condition!). Price 900,00 NOK.
This trunk liner will only fit models with fixed back seats! It is very hard to find a trunk liner in such a good condition nowadays.
There are no oil stain or animal hairs on it.
BMW E39 535i / 540i / M62 K&N Air Filter. Price 450,00 NOK.
This air filter was used for 15.000km. However you can clean it and soak it with special K&N oil and reuse it as many times as you want.
The air filter comes with a matching mounting bracket and a rubber ring which is necessary to mount it on the air flow meter.
I will also include two pipes which suck cold air from the front of the bumper.
Endret av gump
