Sony xplöd 12" sub selges, Brukt i ca 3-4 uker.
http://www.bilradiospes.no/prod_detaljer.php?id=560
Maks. Power: 1200 Watt
RMS: 350 W
Følsomhet 89 dB/W/m
Frekv. område: 18 - 2kHz
Polypropylen membran med gummi oppheng
Dls ca41 forsterker selges, Brukt i ca 3-4 uker den og.
RMS output per channel at 13,8 volts
Mode : AB
Number of channels : 4
Nominal power output in 4 ohm (0,1% THD) : 4 x 50 W
Typical power output in 4 ohm (0,1% THD) : 4 x 70 W
Maximum power output in 2 ohm (0,2% THD) : 4 x 125 W
Max power output in 4 ohm bridge mode : 2 x 200 W
Frequency range : 10 Hz - 35 kHz
S / N-ratio, A-weighted : > 100 dB
Damping factor : > 100
Input impedance low level : > 10 kohm
Input impedance, high level : 100 ohm
Input sensitivity, variable : 0,25 - 5 V
High level input with auto start : Yes
Low level output : Yes
Filter channel A & B : HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10)
Filter channel C & D : HP: 15-500 Hz / 150 Hz - 5 kHz (x10)
Grand bass adjustable frequency : 25 - 80 Hz
Grand bass adjustable level : 0-18 dB
Current draw, idle : 0,7 A
Fuse value : 2 x 30 A
Dimensions H x D x B : 67 x 354 x 250 mm (2,63 x 13,93 x 9,84 inch)
Weight : 4,2 kg ( 9,3 lb)
Kom med bud:D
