BalleKnalle
Alt skrevet av BalleKnalle
  1. Har du snakket med forige eier da? Kanskje han har peiling på om den er byttet??
  2. Kul vekkerklokke az
  3. Er det ikke et klistermerke eller noe i motor rommet da? Pleier å stå på slike..
  4. I USA er det vel lov å skyte vedkommende som enten stjeler bilen din eller bryter seg inn i huset ditt....
  5. Here's how it works: In overhead cam engines, the cams are connected to the crankshaft by either a belt or chain and gears. In BMW VANOS motors there is a chain and some sprockets. The crankshaft drives a sprocket on the exhaust cam, and the exhaust cam sprocket is bolted to the exhaust cam. A second set of teeth moves a second chain that goes across to the intake cam. The big sprocket on the intake cam is not bolted to the cam, for it has a big hole in the middle. Inside the hole is a helical set of teeth. On the end of the cam is a gear that is also helical on the outside, but it's too small to connect to the teeth on the inside of the big sprocket. There is a little cup of metal with helical teeth to match the cam on the inside and to match the sprocket on the outside. The V (Variable) in VANOS is due to the helical nature of the teeth. The cup gear is moved by a hydraulic mechanism that works on oil pressure controlled by the DME. At idle, the cam timing is retarded. Just off idle, the DME energizes a solenoid which allows oil pressure to move that cup gear to advance the cam 12.5 degrees at midrange, and then at about 5000 rpm, it allows it to come back to the original position. The greater advance causes better cylinder fill at mid rpms for better torque. The noise some people hear is the result of tolerances that make the sprocket wiggle a bit as the cup gear is moved in or out. Double-VANOS (double-variable camshaft control) significantly improves torque since valve timing on both the intake and outlet camshafts are adjusted to the power required from the engine as a function of gas pedal position and engine speed. On most BMW engines that use a single VANOS, the timing of the intake cam is only changed at two distinct rpm points, while on the double-VANOS system, the timing of the intake and exhaust cams are continuously variable throughout the majority of the rpm range. With double-VANOS, the opening period of the intake valves are extended by 12 degrees with an increase in valve lift by 0.9 mm. Double-VANOS requires very high oil pressure in order to adjust the camshafts very quickly and accurately, ensuring better torque at low engine speeds and better power at high speeds. With the amount of un-burnt residual gases being reduced, engine idle is improved. Special engine management control maps for the warm-up phase help the catalytic converter reach operating temperature sooner. Double-VANOS improves low rpm power, flattens the torque curve, and widens the powerband for a given set of camshafts. The double-VANOS engine has a 450 rpm lower torque peak and a 200 rpm higher horsepower peak than single-VANOS, and the torque curve is improved between 1500 - 3800 rpm. At the same time, the torque does not fall off as fast past the horsepower peak. The advantage of double-VANOS is that the system controls the flow of hot exhaust gases into the intake manifold individually for all operating conditions. This is referred to as "internal" exhaust gas re-circulation, allowing very fine dosage of the amount of exhaust gas recycled. While the engine is warming up, VANOS improves the fuel/air mixture and helps to quickly warm up the catalytic converter to its normal operating temperature. When the engine is idling, the system keeps idle speeds smooth and consistent thanks to the reduction of exhaust gas re-circulation to a minimum. Under part load, exhaust gas re-circulation is increased to a much higher level, allowing the engine to run on a wider opening angle of the throttle butterfly in the interest of greater fuel economy. Under full load, the system switches back to a low re-circulation volume providing the cylinders with as much oxygen as possible.
  6. Vanos and double-Vanos (double-variable camshaft control) improve the torque curve of an engine significantly. The special feature of both Vanos and double-Vanos is that they react to the engine speed and the position of the accelerator, adapting valve timing on both the intake and outlet camshafts by even the slightest quantities to suit the running conditions of the engine. The result is even more torque at low speeds and superior performance at high revs. The reduction in unburnt residual gas improves the idling qualities of the engine, and special control maps for the warm-up phase enhance the efficiency of the catalytic converter. The car's Digital Motor Electronics (DME) are responsible for the fully-variable control of Vanos and double-Vanos.
  7. Prøv kjøp & salg tråden...
  8. Har aldri hørt om Blitz felger før men .... Hadde du hatt bilder så har det kanskje hjulpet litt?
  9. Au... Det så ikke noe særlig godt ut...
  10. Er det ikke en type E30 M3 som er levert original med røde seler da? Synes jeg husker det fra en artikkel jeg leste i et blad en gang.. E30 M3 EVO et eller annet..
  11. Gratulerer med kjøp ja. ...Har hørt at du kan få mye mer effekt ut av E21 ved å bytte ut motordeler med E30.. F.eks E30 topp osv.. Husker jeg leste om trim tips av E21 i Performance BMW (enkelsk blad) stod mye der..
  12. Hm.... Ikke bra hvis det faktisk er sant da.. Når en tenker litt etter så kan jo de fleste lese på forumet om prosjekter og spesiele biler.. Kan fort bli bestillingstyverier på slike biler.... Eller om noen "bare" vil ødelegge for noen andre.. Synd at slikt skjer....
  13. Hvis du går inn på nye deler, motor, klikker deg inn på denne tegningen.... E36, coupe, 320iM52. Så står det registerkjede på delebeskrivelsen....
  14. Spør du meg så spør jeg deg..... En må vel bare komme med den berømte unnskyldningen; Og slenge på et smil.... Virker litt snodig å montere seter inne i verksted hallen til biltilsynet liksom.. .. Med mindre du må søke eller noe sånt i forveien og få papirer på at du skal "bygge" om.... Men har ikke gjort dette selv, så det finns vel noen andre med bedre peil enn meg på dette....Men det beste, som sagt, er vel å snakke med dem....
  15. Beste er vel å ringe til ditt lokale biltilsyn å høre der... Men en skulle jo tro setene skulle vært montert før visning? de skal vel sikkert kontrollere at alt er forskriftsmessig gjort osv...
  16. Hvis folk lurer på slike spm. så kan dere gå inn på GS bildeler å taste inn f.eks reg nr.(el biltype/motor) deres å sjekke under motor, på deler.... Der finner dere ut av slike ting
  17. Stilig & anderledes bil. .. Eneste jeg savner er sideskjørt og bakfanger som rekker like langt ned som fronten.... Så at du hadde mange forskjellige felger på bildene....? Synes felger med litt utstikkende kant blir penest som f.eks. på dette bildet..
  18. Hakke peil.... Men hva mener du med "fine" vinger? ' Vingen over er sikkert valgt ut ifra lett vekt + aerodynamiske egenskaper+++++++ (som sagt; har ikke peiling )
  19. BalleKnalle
    s4/s6
    http://www.naf.no/eway/default0.asp?trg ... 2::4,935:1
  20. Denne er jo original på M3 GTR løpsbilen.... den er der for en grunn tenker jeg..
  21. Ble bra det der... Har du slike lykter som går i ett med blink?
  22. Jupps.... Thats a beemer...
  23. Hmm... Ikke så sinnsykt pent. Ser ut som noen har hadd det gøy med photoshop på en BMW X5 Den er vel vist før tror jeg.... Men hvis M3 får slike kurver sier ikke jeg nei takk vertfall...
  24. Hm... Kjører Golf for tiden jeg.....
