Selger Innovate Motorsports LM-1 Basic Kit med LMA-3 AUXBOX
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition. The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program: Added Functionality with the LMA-3 AuxBoxThe AuxBox attaches to the auxiliary input of the LM-1 and allows a user to log and analyze 5 critical engine metrics in addition to the air/fuel ratio native on the LM-1. The AuxBox makes the LM-1 into a complete tuning kit, allowing the user to capture, view, and analyze data on all 6 channels that the LM-1 can log internally. Correlating AFR, RPM, MAP, and CHT, for example, is essential when tuning piggy-back fuel controllers, ECU programmers, aftermarket ECUs, or racing carburetors. The 5 internal sensors are intended for capturing Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), RPM conversion (from a tach signal or inductive clamp), Acceleration, and Injector Duty Cycle (or Dwell). The internal MAP sensor is a 3-bar absolute pressure sensor, providing accurate data up to 44.1 PSIA. The temperature measurement circuit features a K-type thermocouple. The internal accelerometer features 2 axis measurements for a variety of mounting options. Another key application of the AuxBox is road testing. Even a dyno doesn’t provide as much real data as road testing. Factors like air flow, side force, and load vary significantly on a real road. With an AuxBox, a user can log 6 channels, in multiple sessions, for up to 44 minutes. Then, back at the garage, simply connect the LM-1 to you PC and view all of you log data. Use LogWorks to view fuel mapping, perform statistical analysis, overlay graphs, and playback a log on the virtual gauges. You can also view realtime data on LogWorks’ gauges if you want to take your laptop on the road. The AuxBox also includes 5 external inputs for connecting external sensors in lieu of the internal sensors. This allows users to log data from external sensors like TPS or suspension data. The AuxBox ships with mounting hardware, a 6’ thermocouple wire, the LM-1 connecting cable, and the user manual. Installation and SetupInstallation of the LM-1 is relatively simple. Complete documentation is supplied, and the support pages, user forum, and tuner resources can also speed you on your way to effective tuning. Innovate also has a great network of local dealers, tuners, race shops, and dyno shops that can assist you in choosing, installing, and getting the most out of your Innovate products. What's in the box:LM1 with 9v battery AuxBox (LMA-3) Input Accessory Bosch LSU4.2 5-wire Wideband 02 Sensor Analog Output Cable 10ft. Sensor Cable 10ft. Power Cable (Cig lighter) 6ft. Serial Cable for PC Connection Bung/Plug Kit Software CD Quick Start Guide Snazzy Innovate Motorsports Sticker
+ induktive pickup og 2 stk ekstra mutter/plug for innsveisingFint for den som skal mappe datasprut evt diagnose, med Aux boksen så har du data fra 6 sensorer som kan lagres på Lm1 evt på pcNytt i eske
Kr 4800,- pluss evt frakt
Mv Tor
