Termistor har blitt et uttrykk ( betegnelse) på Resistor det siste.
Var ikke meningen å forvirre noen.
Men fra Bilfagskolen hadde vi aldri den betegnelsen.
1- How does the coolant temperature sensor "CTS" work?
The coolant temperature sensor is a thermistor ( a resistor which varies the value of its voltage output in accordance with temperature changes. ). The change in the resistance values will directly affect the voltage signal from the water thermosensor. As the sensor temperature decreases, the resistance values will increase. As the sensor temperature increases, the resistance values will decrease.
Vi brukte NTC og PTC Resistor fordi det ved feilsøking fortalte oss hva vi lette etter.
Men lykke til.
