stian328i
Alt skrevet av stian328i
  1. Det er mulig men da må man vel få tak i nytt og større spjeld?
  2. Dette er jeg ikke sikker på men det er mulig de kan vere modifisert siden det ble skrevet at han kunne ta de gamle delene jeg tar av i inbytte for reduksjon i pris. Har hørt at en mulig må ha en adapter på innsug vist du har M50B25 manifold.det som er sikkert er at dette er noe jeg skal prøve...
  3. For dere som lurer på innsug og større spjeldhus til 328i.Sente en mail til linken på E36coupe.com og fikk dette til svar! I can send a kit to you in Norway, but I will need a £100 deposit on your old items, which I will refund on return of the parts. Here are the details: The Bbtb/manifold conversion is designed to remove the restrictions that BMW deliberately built into the M52 2.8 engine. They did this to restrict the power to 193 bhp (the same bhp as the old 2.5 unit). The reason for the restriction is the German insurance market, which penalises cars which have more than 194 bhp. However, the 2.8 has a much better torque figure than the 2.5 unit. It will fit all E36 328s and all E39 528s up until 1998 model. It will also fit he 323 /523 models with similar gains in bhp. The kit takes about 4 or 5 hours to fit. The only downside after installation is the fuel rail cover cut outs don’t quite match the manifold, though it is barely noticeable. Also a small piece of one of the fuel rail bracket needs trimming off. Everything is reversible, should you ever wish to resort back to the original. Power gains with a free flow filter are in the region of 20 -25bhp, typically giving around 218bhp on a 328 and around 193bhp on a 323.. Tests have shown that this manifold will flow 275 cfm of air as opposed to the standard 185cfm! Schrick make a free flow manifold, which costs £900 without the body! The Schrick unit flows 250cfm. The manifold itself is an extensively re worked second hand M50 manifold. The modified manifold has a new custom made chamber, screwed and bonded into the underside, which houses the idle valve, air sensor, and oil recirculation valve in exactly the same position as the original M52 manifold. The manifold comes complete with the previously used seals that came with it. Though you might prefer to buy new ones. I can supply new seals at £25 for a set of six. There are also two new special fittings, which accept the standard M52 stabiliser brackets and idle valve cage. Also in the kit is a big bore throttle body and if you have 'ASC', a big bore traction control body. These are sold on an exchange basis, where you return your old body or bodies once the kit is fitted. I will also need the plastic chamber from your old manifold that houses the idle valve etc. The manifold comes with a slightly reworked one already fitted. E39 5 series models require a Pas reservoir relocation bracket at £15. I can supply a brand new manifold instead of a second hand one at an extra £210. You can retain all your old parts for an extra £115. This conversion has to be easily the best power per pound that you can buy for the M52 328/323 engine. The engine revs all the way to the redline without any hesitation at all. Whereas the standard engine struggles from 4,500 revs. The cost is £325 without traction control or £375 with traction control. + £20 postage. I can fit the kit for £100 (In Essex) I can supply the throttle body on its own which can be fitted prior to the full manifold conversion. This will cost £120 for non traction or £170 with traction control. These are exchange prices, so I will need your old ones back after fitting. The manifold can be added later. In Summary Bbtb/manifold kit £325 with exchange throttle body. Bbtb/manifold kit with ASC (Traction Control) £375 with exchange throttle body. With both of the above options, I will need your old throttle body and plastic icv chamber/seal returning to me after fitting. If you have ASC, I will also need the ASC unit. Pas relocation bracket for E39 5 series £15 (Not required for E36 323/328) If you prefer to keep your old parts, please add £50 for the throttle body, £50 for the ASC unit, and £15 for the icv cover. The manifolds are second hand. If you prefer a brand new manifold, then please add £210 to the overall price. New manifold to head seals are £25 per set of 6. Fitting is £100 Postage is £20 You can phone me on 01245 442851 or 07968 391056. email alpina527@aol.com Thanks, Ian
  4. passer big bore throttle body til 328i (m50) motoren også????samme som de skryter av på E36coupe.com? for da kjøper jeg det med en gang
  5. he he fikk tak i ett i dag kr500 men hvor mye koster adapter?
  6. stian328i
    325 innsug
    har noen peiling på hvor jeg kan få tak i 325 innsug og eventuelt big bore spjeldhus???
  7. jeg er 20 år og kom unna billig med gjensidige.har 328ia og betaler 7600 i året
  8. Er det noen som veit hvor jeg kan få tak i girkule til automat?
  9. Har noen tips om hva jeg kan gjøre for å få litt xtra power i en 328i?uten at det blir aaltfor dyrt
