google er din venn. kopi fra en ann forun
If you have ever tried to change rear wheel bearings on an E39 you will all ready know that it doesn't happen like the books say !
You just aint going to pull the hub from the bearing ( not very often any way) even with the hub puller tool.
I have come up with a method which I successfully used to replace both rear bearings yesterday, now at fist glance it would appear to be a thug heavy handed "bodge " job - it is not and it requires a delicate and confident hand.
You will need a fly wheel puller - a cheap generic one will do and a set of reversed torq sockets (star head sockets).
Here goes - Jack up and remove wheel and put on axle stands.
Remove brake calliper and brake disc.
Undo the 4 star head torq bolts holding the bearing to the hub carrier - they are hard to get at and it is some times easier to jack the hub carrier up and down until the bolts can be accessed . ( spray some release oil on the threads that can be seen behind the handbrake shoes - it really helps)
Take off Remove the Drive shaft Nut.
With all 4 out now use the puller to remove hub and bearing from the drive shaft - this is way way easier than pulling the hub from the bearing which is a tool breaking , knuckle skinning impossibility.
Now for the controversial bit
With the hub and bearing mounted firmly in a vice cut two 45degree cuts across the outer race of the bearing with a disc cutter - you may not get the cut all the way across - this is ok - just don’t cut in to the hub.
Now use a cold chisel to split the outer race and remove with all the bearings.
You will now have the inner races left on the hub ( which is the best you will get if you are successful with a puller) .
Now again cut diagonally across both races and remove with a cold chisel
I found removing the guard and using a small almost worn out disc worked best.
You will now have a free hub.
Bolt in place new bearing , slot hub on to drive shaft splines and gently squarely until you can get the driveshaft nut on ( use a block of wood so you can tap it on in the centre of the hub)
Now pull the bearing in using the drive shaft Nut.
I know that there plenty of BMW mechanics out there rolling the eyes to heaven and calling me a butcher but I could not afford the 5 hours @ £75 per hour I was quoted to have the job done for me .
It took me 3 hours start to finish - and if you totally balls it up a new hub is only £30 from euro parts so go for it!
