Ikke sant..Det er jo ingen tvil at man får hva man betaler for. Men de BC racing coiloversene som jeg har sett på er jo ikke såå billige . Og det er i tillegg i US. Har sendt de en melding melding på face og spurt om de er tüv godkjente. Er de ikke det så er det jo ingenting å lure på. Det som er gromt med dette kittet er hvordan de er bygd, i tillegg så er det med camberplater foran.
Product Description
BC Racing RAM Series Inverted Coilovers
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Circuit Motorsports is one of BC Racing’s Largest Authorized U.S. Dealers, we have years of experience with BC Racing kits and we are available to help you with any questions or to give suggestions on a custom setup. If you desire a custom kit with different spring-rates we can accommodate you! Simply place your order and on the checkout screen in the Comments box list the rates you would like. We will contact you to make sure the kit is ordered correctly if needed. Please Email, Call, or Message us if you have any Questions on the BC Racing coilover kits, we as can help you with anything you need and we will make sure you get the best buying experience through us.
