Dette er koblingene jeg har fått gjort så langt på KDFI
Pin 1 : Fuel pump -> FB
Pin 3 : Injectors 2&3 (e36 only) -> INJ2
Pin 6,28,34,55 : Earth -> GND
Pin 12 : TPS -> TPS
Pin 14 : VAF sensor (volume/iar) leave unconnected
Pin 15 : Knock sensor cyl 1&2 (KS1) -> JS5
Pin 16 : Camshaft Position (CMP) sensor (ground)
Pin 17 : Instrument Panel (trip computer)
Pin 18 : Intake manifold air control solenoid
Pin 24 : Ignition Coil (CYL 3) -> A2
Pin 25 : Ignition Coil (CYL 1) -> A1
Pin 26 : Battery – always +12v
Pin 27 : Engine Control Relay
Pin 29 : Idle air control (IAC) Valve -> FDL2
Pin 32 : Injectors 1&2 (e36 only) -> INJ1
Pin 36 : EVAP
just leave unconnectedPin 37 : Oxygene Sensor Heat relay
Pin 41 : Volume Air Flow (VAF) Sensor
Pin 42 : Knock Sensor (Cyl 3&4) KS2
Pin 43 : Engine Coolant Temprature (ECT) Sensor –> CLT / GND
Pin 44 : Camshaft Position (CMP) Sensor (probably not needed)
Pin 51 : Ignition Coil (CYL 4) -> B2
Pin 52 : Ignition Coil (CYL 2) -> B1
Pin 54 : Engine Control Relay
Pin 56 : Ignition Switch –> 12V
Pin 59 : Throttle Position (TP) Sensor
Pin 67 : Crankshaft Position (CKP) Sensor –> RPM?
Pin 68 : Crankshaft Position (CKP) Sensor GND
Pin 70 : Heated oxygene (H02S) Sensor –> OXY
Pin 71 : Heated oxygene (H02S) Sensor GND
Pin 73 : Instrument Panel –> Tacho output (signal for the tachometer) JS10
Pin 76 : Volume Air Flow (VAF) Sensor (Not needed for alpha-n)
Pin 77 : Intake Air Temprature (IAT) Sensor –> AIR / GND
Pin 78 : Engine Coolant Temprature (ECT) Sensor –> CLT / GND
Skal få loddet inn transistorene til coilene og få testet dette i bilen en dag snart, er det noen som har en grei startup map for orginal dysene ?
Er litt usikker på hvilke verdier jeg skal bruke for å sette injectors size i kdfi oppsettet for dysene, mine orginale er vel 170cc ?
Semi-Sekvensiell injeksjon og VR veiv trigger, 60-2 veiv sensor, første tann tannvinkel er 118 grader
Tenningen fyrer 1-3-4-2 og bensininnsprøytning sprøyter inn halvsynkront - 1 & 3 og 2 & 4 blir avfyrt i par
Halvparten av drivstoffet blir sprøytet inn mens eksos ventilene står åpne, den andre halvparten blir sprøytet inn mens stempel er på tur opp rett før den fyrer.
Gikk greit få få den kobblet til pc, har satt inn en ekstra strøm plugg for å tilføre spenning mens den ligger på benk.
Instrument panelet, har bare fått kobblet opp turteller og volt meter.
