eeduu
  • Interesser:
    Sveio
eeduu's Achievements
  1. Det skal gå med elight modulen for "walk me home" mener jeg, har den ikkje selv men vurderer sterkt å kjøpe.
  2. Er det noen som vet om det går å få farten i det lille displaye i instrumentpanelet uten å måtte gå inn i menyene der hver gang eg ska kjøre? Det hadde vært veldig tøft. Er det også noen som vet om det går å feste flere funksjoner til BC knappen?
  3. Her en noen funksjoner du kan få fram gjennom kjørecomputeren via instrumentpanelet. Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the following functions BMW E46 On-Board Computer (OBC) Hidden Codes: 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1 belt contact, seat belt fastened=0; 2 ignition lock contact, key inserted=0; 3 door contact, door open=0; 4 clock button pressed=0; 5 SI reset=0, for reset=0; 6 EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1 Gong output; 2 Brake warning lamp; 3 Low fuel warning lamp; 4 EGA lamp; 5 seat belt lamp; 6 manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of testAndre funksjoner du kan få fram gjennom å bare gå inn i kjørecomputeren via instrumentpanelet:
  4. Noen som selger sin e46 compact? Helst ikke over 60 000
  5. Den oppskriften er jo for å programmere chippen, det har jeg gjort men den vil fortsatt ikke starte bilen :S
  6. emm, kan hende jeg virker litt noob nå, men hva er initialering? har forresten bare manual på tysk, så må søke på google
  7. Men den ligger i chippen? for som sakt så prøvde eg orginalnøkkelen uten chippen i, og den startet ikkje på den heller... og det e jo den orginale chippen eg har i den nye nøkkelen og :s sorry hvis det er noe eg missforstår no, men ble forvirrende
  8. Men... Den orginale nøkkelen starter jo ikke bilen uten chippen, så jeg trodde det bare var chippen som skule til for å starte den..?
  9. hm, suger jo at jeg har brukt mye penger på en nøkkel som ikke kommer til å virke da men takk for hjelpen
  10. låseservice/trioving, de sa det skule gå fint... hvorfor slår startsperren inn om nøkkelen er identisk? :s
  11. Jeg har fått filt en ny nøkkel til min e46 320d touring 01. Jeg har fått kodet chippen så den viker på sentrallås, men når jeg vrir nøkkelen i tenningen så starter den ikke... den går hele veien rundt, og lystest osv kjøres, men ingen reaksjon når jeg vrir den siste hakket. Noen som vet hva som er gale? er det en dårlig kopi? Takker for svar.
  12. Hei, jeg ønsker å kjøpe en framfanger til en e46 touring 01 modell. Jeg har den orginale nå så vil oppgradere til framfanger etter facelift om den passer, eller en annen framfanger. Den må helst være i orginal svart, og ikke altfor dyr. Det gjør ingenting om det er små riper på undersiden.
  13. Må bare høte hvor mye det koster å lakkere den først så kommer jeg tilbake til deg
  14. Hei, hadde en ulykke som førte til most framskjerm på høre side, er det noen som selger en slik som ikke er altfor dyr? Den må være uten rust!
