fikk svar fra koni på mail, visst noen andre lurte på dette...
Yes, both the adjustable KONI Sport shocks and struts (yellow) and the KONI FSD shocks and struts (gold) will work very nicely with your factory springs and the car will sit at the same stock ride height. The Sport shocks are a bit of a sportier ride quality and firmness and are adjustable front and rear for rebound damping to tune to your own preferred ride and handling preferences as well as to compensate for wear over the long term (100,000+ miles or more). The KONI FSD dampers are not adjustable by the user but have the patented Frequency Selective Damping valving feature that while certainly improving the handling of the car will also very much smooth out the impact harshness transmitted into the car from road bumps, impacts, etc. Whereas the Sport dampers will notably improve the handling while moderately firming up the ride a bit and give you personal tuning options, the FSD are more about higher refinement of the ride quality while making a notable handling improvement to the car over the factory dampers.
Either option will work very nicely on your BMW E39 5 Series. WE do have different models of the Sports and the FSDs depending on if you have a 6 cylinder or an 8 cylinder E39 so please select the dampers that best match your car.
